starting issue - need help
Old May 4, 2013 | 05:24 PM
slacker's Avatar
have a fella , brought his 93 to us with an already swaped 3.4L
major issues with the engine one of them no start .
was running for about a year he said , and started to have a knock ..
2 codes - P0330 and P0171 before customer unpluged the ECU
major vac leaks , and #5 cylinder was full of oil , and the knock .. so we suggested re & re of the engine .
re & re is done .. so new 3.4 in there ..
heres the problem I'm having ... no start !!
we have fuel
we have spark , and
we have air ... but engine wont fire ?
anyone EVER had a COR go bad ? i'm thinking this is a wiring issue , just deterating over the last year ,
we swapped the igniter , AFM , plugs as a"quick check" , but i dont know at this point
any help would be appreceated
Old May 5, 2013 | 06:23 PM
vasinvictor's Avatar
First of all, what a PITA to take on someone else's "custom" wiring job. To my knowledge, a COR is just a relay and you could easily swap it out with a new one. You could always hit it with some ether in the intake to see if it hits. Got a reading on the fuel pressure at the rails?
Old May 5, 2013 | 08:58 PM
vital22re's Avatar
totally a bro
Sorry to say it but you gotta start at the wiring. Take it apart and and verify that its getting the power and grounds it needs. Will it cough with starting fluid? is there damage to the crank timing gear? Are the cams timed properly? ecu match the rest of the electronics?
Old May 6, 2013 | 08:57 PM
dntsdad's Avatar
Just jump the relay to test the cor.
Old May 7, 2013 | 05:19 PM
slacker's Avatar
thanks fellas .. got er' done ..
raft of problems , but got them all straightened out . Re wired, replaced issues and customer drove off today ..
he said he'll be back , but not for this problem I hope
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
