3.4 swap bogging sputtering miss fire issues
Old Sep 18, 2013 | 07:38 PM
2000taco's Avatar
Just finishe up my 3.4 swap in my 89 Toyota pickup v6 m/t. The 3.4 is from a 99 4runner a/t.
Toy only swaps repinned my harness and swapped the exhaust around. Along with found me a m/t computer that matched the harness.
Motor is in every thing is complete. So onto the problem;
Start it up and idles perfect (unsure of rpm have not attempted the tach mod)
As soon as you get on the gas and get too 2000 rpms it starts missing and sputtering and occasionally back fires threw the intake. Until you get roughly above 4000 rpms than it smooths out and runs great
When I swapped the motor in I replaced the following,
Ngk double plat plugs
Ngk wires
Timing belt
Water pump
Bearings
I tried to swap coils with my buddy's truck and same thing.
I have double check my grounds they are all tight and clean, no vac leaks.
I'm at my whits end some one please help me before I set on fire! Lol
Old Sep 19, 2013 | 05:45 AM
2000taco's Avatar
Also when it starts back firing/spitting sputtering its kickin put alot of extra un burnt fuel from the tail pipe acting as if it cuts spark for some reason???
Old Sep 19, 2013 | 07:50 PM
2000taco's Avatar
I believe I have solved my own problem, I had saved the whole stock intake but the filter box was junk I cut the tube off flush with the box and put on a cone filter. Fired it up and no issues what so ever. The intake I built for it was letting air in after the maf making it get to much air for what it needed.
Old Sep 19, 2013 | 07:53 PM
Kiroshu's Avatar
Glad you found your problem.
Old Sep 19, 2013 | 07:58 PM
2000taco's Avatar
Thanks hopefully it will help some one else out in the future, now it's onto trying the tach mod
Old Sep 19, 2013 | 10:09 PM
4x4runr's Avatar
Woohoo!! Congrats!
Tach mod is really easy good luck and post some pics!
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
