Oil Sensor Gauge
Old Aug 27, 2013 | 10:20 AM
devharm's Avatar
Oil Sensor Gauge
Hey yall i was just curious, what im supposed to do to connect the oil pressure gauge up to the harness. which clip is it? i cant find on my old harness anywhere the correct clip for the job. any help will be appreciated!
Old Aug 29, 2013 | 09:46 AM
SacRunner's Avatar
First off, you know you need to swap the 3.0 oil pressure sensor over to the 3.4 right? (The 3.4's will burn up the gauge in the dash).
As you're dismantling your 3.0 be sure to make a note of which wire was plugged into the oil pressure sensor, you may need to cut the connector off the 3.0 wiring harness and replace the 3.4's connector with it.
As for finding the connector on the 3.4 harness, grab the 3.4's EWD and compare all the connectors on the harness with the ones at the end of the EWD, and make a note of their names/functions; eventually you'll find the correct one.
Old Aug 29, 2013 | 10:13 AM
devharm's Avatar
I think i have gotten all of that down. I actually ordered a oil gauge sensor from a SR5 dash cluster that was recommended from ORS. hopefully it clips directly up to the terminal i have on my harness
Old Sep 13, 2013 | 10:00 PM
DeathCougar's Avatar
Sorry, but you are wrong.
My 3.4 swapped 89 4Runner uses a fuel pressure sender from a 2001 Tundra, so a 3.0 sensor and cut/splicing is completely unnecessary. Toyota DID however make the correct sender starting in 1993 IIRC in the 3.0, which has the same plug as is on the 3.4 wiring harness.
OP: For plug and play, find an oil pressure sensor that looks like this:
It plugs into the block where the idiot light sender was, but will relay correct oil pressure up to your stock gauge. It should be very obvious once you have the wiring laid across the engine, there are only 2 (or 3, if your 3.4 had ADD) plugs running down the left side of the engine. One is a one wire plug that will have plugged into the oil sending unit. 4Runners and Tacomas only had idiot lights, never an actual gauge but a wire is a wire in this case, it cares not what type of gauge you had/have.
Old Sep 13, 2013 | 10:11 PM
devharm's Avatar
There the exact one I got!
Old Sep 14, 2013 | 04:28 AM
rachjake's Avatar
So, according to post #4, the 2001 Tundra oil pressure sending unit will plug into my 1996 3.4 wiring harness and correctly operate the oil pressure gage in my 1991 SR5 truck. Is this correct? What is the part number?
Thanks
Old Sep 14, 2013 | 07:42 AM
Thanks
Yep that is correct. You can also simply use one from a T100 or late model 2nd gen 4Runner. I have two swapped vehicles; one has an engine from a 1999, the other from a 1997 and both use the same sender from a Tundra.
Not sure what the part number is from Toyota however.
Old Sep 14, 2013 | 07:50 AM
rachjake's Avatar
Did some checking. There appears to be 2 styles, 1 with indicator light and 1 with gauge. The one with gauge part number is 83520 60050.
Thanks
Old Sep 14, 2013 | 08:31 AM
Correct. DO NOT get the indicator light style if you have a gauge!!! It will fry the gauge.
Old Sep 24, 2013 | 12:47 PM
rachjake's Avatar
A less expensive alternative appears to be Beck/Arnley # 2011763 available thru Amazon for under $30.00
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
