Removing 3.0 Wiring Harness
Old Apr 6, 2014 | 04:03 PM
amites's Avatar
So I've been digging on this thing for several hours
I have the ECU disconnected and the wires for it have gotten through the firewall into the engine compartment
What's throwing me off is the wires that go from the engine compartment relay to the fender area on both sides (all front lights, etc...) and then into the dash harness (I tracked them that far but haven't cut anything yet)
doesn't seem to be a clean way to disconnect them and I'm left scratching my head -- please someone tell me I'm missing an elusive obvious
Old Apr 6, 2014 | 06:22 PM
amites's Avatar
took another look after posting this and figured it out
the driver side has 2 connectors inside the cab which can be fished through the firewall
passenger side can be disconnected at the relay box
now time to pull out the soldering iron...
Old Apr 15, 2014 | 05:19 AM
vasinvictor's Avatar
Do what you want, but we don't remove our 3.0 harnesses. We splice the ECU connectors onto the factory harness. Or make a swap harness that adapts to 3.0 plugs to the 3.4 ECU. You should realllllly read the sticky threads, at least "swap101" before tackling this.
Old Apr 15, 2014 | 05:35 AM
JasonYota's Avatar
^^ this. I made my own adapter harness also.
Old Apr 15, 2014 | 09:45 AM
amites's Avatar
been working a franken-yota
have a 96 auto harness, mt connectors and mt ecu all on order right now
read a bunch, pulled the harness to be able to work on it at a bench vs under the hood/tarp in the snow (I live in the rockies -- april always drops a few feet)
appreciate the heads up -- hoping to not make any more silly/costly mistakes
Old Apr 15, 2014 | 09:48 AM
JasonYota's Avatar
All you need is several inches of wire from the plugs that you cut to make an adapter harness
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Doug4320
Mar 24, 2018 10:11 PM
Coreyr384
Jul 10, 2015 11:13 AM
