data link connector ?
Old Mar 12, 2014 | 08:11 PM
toyotamonster's Avatar
Anyone have a pic or the wiring diagram for the data link connector on a 98 Tacoma 3.4 with an auto trans? I had to source a connector out of a 97 Lincoln continental and wondering what pin outs I need to put wires in. I know what wires I need just cant find a pic of where in the connector they go. Thanks for the help.
Old Mar 13, 2014 | 08:39 AM
SacRunner's Avatar
Assuming you're talking about the OBD-II connector (not the one in the engine compartment), start here: https://www.google.com/#q=obdii+pinout
If that's not specific enough, pin 2 is your signal line (SDL, in Toyota EWDs), pin 4 is chassis ground, pin 5 is signal ground (can just be connected to ground), and pin 16 is +12V (from a 7.5A fused, always on source).
Old Mar 13, 2014 | 07:28 PM
Yes the obdII connector sorry. I was able to figure out after reading multiple posts that it's the D7 plug so that helped. I found that in the diagrams I downloaded and figured it out from there. Thanks for the reply. 2 more wires to connect and then fill with fluids to see if she starts:-). After reading all the build threads on here I was obviously lucky on my first swap to have it fire and run perfect on the first try. Hopefully this one goes the same
jb451
7
Oct 7, 2022 06:58 AM
some drunk guy
Aug 3, 2021 06:09 PM
Obmi
Sep 10, 2016 04:40 AM
mct75
Aug 22, 2016 01:24 PM
Obmi
Nov 24, 2015 11:37 AM
