Crossover pipe newer style -- advice?
Old Apr 25, 2014 | 04:40 PM
amites's Avatar
I have a newer style exhaust crossover pipe and drawing a bit of a blank on how to modify it to re-route driver side given the joint piece being solid
anyone have advice for how to do it? other than just buying a new pipe from ors?
did a search found a bunch with the older style which looks pretty straight forward, but hoping to avoid buying more parts right now...
thank you
Old Apr 25, 2014 | 08:21 PM
wyoming9's Avatar
Red face
I know I saw quite a few write ups on doing your own crossover pipe .
Mine is solid and I never gave it any thought .
Just what are you not sure of??
Old Apr 26, 2014 | 06:52 AM
amites's Avatar
took a fresh look and think I have an approach
it's the Y at the end that I'm not to sure about, but thinking I can grind it down flip it around and otherwise re-assemble similar to the older style
have a piece of flex pipe I pulled from a yard handy to make it a bit easier
Old Apr 27, 2014 | 12:49 AM
wyoming9's Avatar
Red face
There are no hard and fast rules I know some that have run the crossover pipe under instead of over the top.
All depends on if ground clearance is a Major Issue in the use of your Truck
Old Apr 27, 2014 | 07:23 AM
donomite49's Avatar
i ran my crossover underneath tucked in close for clearance, eliminating extra heat under the hood and against the firewall.
win win...
like stated above if you route the exhaust underneath you need to route it with ground clearance in mind.
Sep 4, 2015 09:27 AM
ia02
Aug 20, 2015 11:04 AM
duncanmc
Aug 19, 2015 03:13 PM
thefishguy77
Aug 9, 2015 04:15 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
