3.4 swapped with a340h trans pulling up p1700 code
Old Dec 26, 2012 | 10:07 PM
david braun's Avatar
Hey I was just able to get my obd2 cable wired in and found out that 1 of 8 codes was the p1700 or speed sensor..
Motor ecu and harness is all from a 98 taco auto to a 95 auto runner..
And I hear you can run a wire from Behind the 95 dash cluster to the ecu? Any wright ups out there or how to's?
If I knew what wire colors to splice into I'd be good to go already did the tach mod btw..
Also other then the cel being on does it affect the engine or trans in any way?
Old Dec 27, 2012 | 04:56 AM
waskillywabbit's Avatar
You need to get the donor and project wiring diagrams and match wiring functions.
Much easier that way.
:wabbit2:
Old Dec 27, 2012 | 06:05 AM
vasinvictor's Avatar
The speed sensor wire you are searching for is already in the 95 body harness right there in the kick panel. You have to get the EWDs for both vehicles and match em up. E12 12 G-O to IH1 20 G-L for me (this one's a freebie)
Old Dec 27, 2012 | 09:06 PM
Thanks man found it
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
andrewtexas123
Jul 14, 2015 04:29 AM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Jnkml
Jul 6, 2015 01:20 PM
