Wiring questions
Old May 11, 2013 | 08:55 PM
robwise's Avatar
Wiring questions
Posting all my questions here instead of starting a million threads.
My particular swap involves an 89 single cab truck with a 3vz and standard 4x4 transmission, a wiring harnes from a 96 standard 4x4 Tacoma and a 5vz from an 98 automatic 4runner.
My current question is about the wiring harness i am building to connect the engine(5vz)wiring harnes to my trucks body harness and one of the connections that involves three wires:
Pin #16 on the white 5vz engine to body (connector ik2 in my tis)
W-R
Male: COR, efi relay, +B, vsv evap
Female: +B data link, vsv vapor pressure sender, MAF meter, o2 sensor, idle air valve
Pin #5 on the grey 3vz body harness (c1)
W-R
Male: COR, efi main relay, a/c idle up, vsv
Female: tccs ecu +B +B1, ox sensor, check connector, fuel pressure up, vsv
Pin #12 on 5vz 4x4 ECU e5 connector
+B
My question is weather or not I solder all three of these wires together or not, also what is function +B?
Old May 13, 2013 | 12:44 PM
NytWolf's Avatar
+B is constant +12V, meaning it goes directly to the battery or fusebox.
And yes, if you have verified that those three wires go to the same place, they would have to be soldered together.
Mine is a 92 5-speed Pickup with a 01 Taco 5VZE, and I ended up needing to solder together three wires also. Couldn't tell you which ones now, but the count was three.
Old May 13, 2013 | 06:20 PM
robwise's Avatar
Alright thanks, I know there is another three wire connection ran from the engine bay for the starter but your talking about a different one right?
Old May 14, 2013 | 07:04 AM
NytWolf's Avatar
I mean same function, not same place as in same connector.
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
