Please help clutch priblem
Old May 31, 2013 | 06:51 PM
Rhodes89's Avatar
Ok guys I have a 3.4 swapped 89 pickup with 99 3.4. I use 3.0 clutch ( wish I didn't) but I have a problem with my pedal my clutch is new iv went through 3 master c. And 2 slave c. Still I have the rod on master c adjusted all the way out and have to push pedal all the way to floor very hard to get it to barley go into gear. When I push the clutch the little u that clips to the pedal doesn't move but inside of it (where rod threads in) moves the rod is secure its inside the clip that moves is that a problem or do I have a pressure plate problem. I don't think it's a throw out barren (no noise) please help... by the way changed the clip on end of master c and it worked for a while now it quit
Old Jun 1, 2013 | 03:04 PM
Rhodes89's Avatar
Anybody?
Old Jun 1, 2013 | 05:39 PM
slacker's Avatar
have you checked the pedal bracket for a crack ? pretty common
Old Jun 1, 2013 | 05:56 PM
Rhodes89's Avatar
No how do I check that
Old Jun 1, 2013 | 06:02 PM
konah's Avatar
crawl up under your dash with a light and look at it...
Old Jun 1, 2013 | 07:31 PM
Rhodes89's Avatar
Ok I'll try that Tomar and if that's the problem ill need a clutch pedal assembly ?
Old Jun 2, 2013 | 03:44 PM
Rhodes89's Avatar
Looks like someone has welded it at one point in time but iv had the truck 3 years and just now havin the problem about 6 months after the swap
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
