Where is the A/C amplifier
Old May 31, 2014 | 08:30 PM
Dmech's Avatar
So I did a 3.4 swap on a buddies 94 4runner, thing runs like a champ, but now its getting hot and I put the A/C on the back burner.
I do not have 12v at A/C clutch
I am trying to wire up the A/C amp as dictated in the the A/C stickyI have combed the forums as much as I can to no avail in finding its exact location.
apparently it behind the glove box, all I see it the rear ABS module fan relays and heater - A/C fuses.
I know the other way to do this is to hop the A/C cut relay, but this relay, per what I have read, exists only on the 4cyl models. I have a 6 cyl at.
Old Jun 1, 2014 | 10:45 AM
aztoyman's Avatar
My 88 4 cyl had it on the A/C box itself behind a little plastic cover. Has wires plugging into it.
I used the one from my 99 donor so it would work properly. It was also mounted on the A/C box.
Old Jun 1, 2014 | 11:01 AM
wyoming9's Avatar
Red face
It is over there some place going by the 94EWD I wonder if it is on the back side of the evap box
Old Jun 2, 2014 | 06:48 PM
Dmech's Avatar
Wink
Still no luck, I have email mike at ORS since he built the harness. I will definitely post it once I find out
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Tacoma1313
Sep 8, 2015 01:27 PM
Rawwdz
Sep 6, 2015 09:03 PM
