ecu gods!
Old Aug 28, 2012 | 05:37 PM
toyotanick's Avatar
ecu gods!
hey guys! i was recently told by gadget that the 96 tacoma ecu cannot handle boost nor does it like it. he said that the ecu retards timing when it sees boost and seriously kills power. so i checked this to make sure and as i figured, he was correct. now, my question is that this should just plug and play correct? also, i originally have a 96 tacoma manual transmission ecu. will it matter if i get an 97 tacoma automatic? i have read that i will need to fool the computer to thinking that it is in neutral which should be easy im hoping.
thanks for the help guys. really wanting to get this thing running right! so that i can bring it to the track and let you know what itll run on 41's!!!
Old Aug 28, 2012 | 06:13 PM
snobdds's Avatar
Why not ask Gadget, he pretty much wrote the book on supercharged 3.4's
Old Aug 29, 2012 | 11:20 AM
toyotanick's Avatar
gave him a called and he basically reminded me of something that i already know. M/T transmission ecu plugs are completely different from a/t plugs so i looked one up on car-part.com called up a reasonably priced salvage yard and have an up to 5/97 tacoma 4x4 m/t ecu on its way! now hopefully this thing actually plugs and plays!
Old Aug 31, 2012 | 07:23 PM
toyotanick's Avatar
well, ive got the new ecu, the truck seams to be running better even though i only took it around the block. but it seamed to have more power. issue is that my timing still seams to be kind of on the retarded side. im wondering what you guys are seeing at full boost? so far i have seen 12 degrees being the worst. also, i am wondering if the ecu will be learning this aswell?.
Old Aug 31, 2012 | 08:27 PM
vital22re's Avatar
totally a bro
are you running a smaller pulley?
running premium?
Old Sep 1, 2012 | 05:01 AM
toyotanick's Avatar
2.1 and premium. The only thing I am not exactly sure of is my afr's. Last time I checked I was running between 11.8 and 12.8 with my methanol
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Boomer8404
Sep 24, 2015 01:12 PM
Dobich
Sep 14, 2015 11:15 PM
zz_denis
Sep 6, 2015 03:43 PM
