? about wire from battery to fuse box
Old Mar 27, 2012 | 05:13 PM
Ahbustae86's Avatar
What size wire should I use to get from the battery to the fuse box?
Should I leave the fusible link that's coming out of the fuse box?
I was thinking running 8awg wire to the fusible link, but someone said going from 8awg to 12awg (estimated size of fusible link) wouldn't be safe.
BTW. Does anyone know the size of the fusible link?
Old Mar 27, 2012 | 05:46 PM
Elton's Avatar
8ga should be fine thats what stock is you could use a inline fuse like one used for a amp
Old Mar 27, 2012 | 08:59 PM
dntsdad's Avatar
What fusible link? 8ga is fine but the wire should go directly the lug on the main power fuse.
At least that is how both that I did were. Perhaps your fuse box is different?
https://www.yotatech.com/forums/f160...23/index7.html
Old Mar 28, 2012 | 10:13 AM
vasinvictor's Avatar
This is how mine is too. 8ga directly from battery to main power fuse. I, too, was not sure what/where a fusible link was.
Old Mar 28, 2012 | 10:15 AM
vital22re's Avatar
totally a bro
My 92 truck has a fusible link before the fuse.
Old Mar 28, 2012 | 10:16 AM
Is it necessary? Or one of those "couldn't hurt" things?
Old Mar 28, 2012 | 02:49 PM
ultimase's Avatar
I believe the fusable link is in the fuse box. It's the big plastic square "fuse" that's in the fuse box. From what I understand it's there because it's not as easy to get as a normal fuse. IE if you blow this you have a serious ground that can cause a fire, and we don't want you to even try running this car until you fix it.
Old Mar 28, 2012 | 03:27 PM
vital22re's Avatar
totally a bro
More than one type. We are talking about a wire type that is before the one in the fuse block.
Old Mar 28, 2012 | 04:24 PM
Ahbustae86's Avatar
Yes. It's the wire one that I have coming out of the box going straight to the battery. Should I just get rid of the fusible link wire and run 8AWG from the lug in the box, add in a fuse and then to the battery?
Old Mar 28, 2012 | 04:30 PM
vital22re's Avatar
totally a bro
If its fused its fused for a reason. Although I do think they were phased out in later years
MO transplant
Apr 23, 2023 11:58 AM
v_man
Jul 23, 2015 04:01 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
Sandman
Jul 14, 2015 12:36 PM
