What to swap in? 99 4runner or 96 t100?
Old Aug 6, 2012 | 08:20 PM
9four4runner's Avatar
so i ended up buying a motor at my work at the local JY and its a 99 4runner 3.4 with ecu and harness(auto 4x4)and about a week later i picked up a 96 t100 5 speed 4x4 witch would be easier to swap in? and least of a hassle?
Old Aug 7, 2012 | 07:18 AM
Ride4Fun's Avatar
What is it going in? Do you have a manual or auto now, and which do you prefer? The 99 4Runner will has a driver side drop on the transfer case. The T100 should have a passenger side drop on the transfer case. Assuming that you are swapping this into a 4Runner or truck that was built before 1996 then your stock tranfer case will be a passenger side drop.
Threrefore, the T100 would be the easier of the 2 considering that you can use the transmission and transfer case. If you choose to use the 4Runner with the auto that came with it, you will have to adapt an early model transfer case to the transmission.
This is all covered in this swap section, you will just need to do a little searching to find the information that you are looking for.
Old Aug 7, 2012 | 08:31 AM
SacRunner's Avatar
Either will work.
What's it going into? Auto or 5-speed? Are reusing your old transmission/transfer case?
Assuming it's going into a 5-speed, the auto 4Runner harness can be re-pinned and depopulated (pins removed) to work with a 5-speed ECU (you'll also need a 5-speed ECU).
I've heard that the T100 engine harness is longer than those of the 4Runners and Tacomas which would make it a bit easier to mount the ECU in the passenger kick panel. I've also heard that all the EVAP wires are part of the body harness on the T100s (vs. part of the engine harness with 4Runners and Tacomas).
Being that you're in CA you will probably want to give a SMOG ref a call (call the 1-800 number, leave a message with a receptionist, the ref will call you back in a couple days) and talk with him to see what you'll need to do to keep the swap SMOG legal, unless you're building it as an off-road only rig.
Old Aug 7, 2012 | 09:13 AM
waskillywabbit's Avatar
On or off road?
Auto or 5 spd?
Those determine which I'd use.
:wabbit2:
Old Aug 7, 2012 | 09:00 PM
sorry its going into my 94 4runner 5 speed 3.0 and i want to keep it as a DD and sas later, insted of trying to make it Cali legal id rather not hassel with it just as long as it runs good im good and later on donw the road ill think about making it Cali legal.
its a stick and would like to keep it stick
ive never herd of the t100 body harness being part of the wiring either guess id have to look it up
Old Aug 31, 2012 | 08:00 AM
bend's Avatar
It is longer. The 96 and 97 model 3.4s are susceptible to externally blown hgs.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
HRDC0R19
Jul 5, 2015 06:43 PM
