P1780 code
Old Aug 7, 2011 | 08:40 AM
Do Over's Avatar
P1780 code
A little background...
85 4runner with the drivetrain from a 2000. The 2000 is (was) a 2 wd auto. I user the Inchworm adapter to mate my duals. ORS wiring
I've had the code from day 1 but, new kid, new house and, a job in finance during the depression has kept me busy.
I replace the neutral safety switch. Problem remained. Worked through This chart http://www.watrd.com/work/cip1780.pdf to find my voltages to the computer were a mess. the voltage is correct on the line corresponding to the gear your in. For instance, if the shifter is in low, the voltage for L is correct. But, the voltage on the other gears climb through the roof.
I'm terrible with wiring and electrical in general so, I apologize in advance if this is a newbie question. Could it be as simple as a bad ground?
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
