3.0 header on 3.4
Old Jun 30, 2011 | 11:33 PM
anthony1's Avatar
3.0 header on 3.4
Anyone tried using 3.0 headers on 3.4 to keep the exhaust on the same side? I'm assuming that they are lined up the same...maybe not...
Old Jul 1, 2011 | 01:56 AM
vital22re's Avatar
totally a bro
will not work. search for the crossover mod in the 3.4 swap section. Its easy peasy
Old Jul 1, 2011 | 06:38 AM
anthony1's Avatar
Thanks. I'm going to get aftermarket headers. I'm ok iwith moving the exhaust to the other side. My gas tank is already moved to the rear. I can go either side.
Old Jul 1, 2011 | 06:57 AM
MaK92-4RnR's Avatar
same block, different bolt holes... wont work. Doug thorley sells long tubes for the 3.4
Old Jul 1, 2011 | 05:11 PM
anthony1's Avatar
cool. I might go with that.
Old Jul 1, 2011 | 05:47 PM
vital22re's Avatar
totally a bro
Beware of your clutch slave cylinder. Most bolt on aftermarket stuff for a 3.4 may not clear it.
Old Jul 2, 2011 | 08:46 PM
anthony1's Avatar
I guess they test the fitment only on automatic...
So would the straight pipe headers might be better for fitment or the ones that joins together at the back of the engine?...
I'm in CA so I need to put all the O2 sensor back too.
Old Jul 3, 2011 | 05:59 AM
waskillywabbit's Avatar
Headers are going to be a tight fit and a PITA all the way around. Be much easier to build a crossover and then if you want go duals from the muffler back. Been there and got the tee shirt.
:wabbit2:
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Valvoman
Aug 8, 2015 03:52 PM
93toyoguy
Aug 2, 2015 07:41 PM
Coreyr384
Jul 10, 2015 11:13 AM
