If someone would supply me with a full electrical diagram for a '97 T100
I will create spreadsheets that tell you which pins are different so you can wire a T100 4x4 Auto ecu to your 3.4 4Runner 4x4 Auto loom. This will fix the speed sensor issue and the sometimes inaccurate transmission shifting. You will also gain 1 - 2mpg. This only works for early 2nd gen 4Runners with the mechanical speedo (90, 91, very early 92's)
I will start with the '98 4Runner 4x4 Auto ecu because thats what I have.
There will be no time frame in completing them and I'll not be responsible for you destroying anything on your vehicle. These will be a guide only, educational purposes, and there may be mistakes. You follow them at your own risk. Sometimes color of wires on the vehicle differ from that of the FSM. I have no way of checking out those anomalies.
Sure, send it. I'll take a look. I can also compile a list of wires changed for same ecu type but different years.
I'm surprised no one has jumped at this offer.
I'v been looking at the EWD's... My 97 4Runner engine did not have a EGR, I've looked at a 95,96 and 97 T100 and the ECU has a sensor for the EGR. Is this going to be a problem?
Thanks!
Thanks!
