If someone would supply me with a full electrical diagram for a '97 T100
I will create spreadsheets that tell you which pins are different so you can wire a T100 4x4 Auto ecu to your 3.4 4Runner 4x4 Auto loom. This will fix the speed sensor issue and the sometimes inaccurate transmission shifting. You will also gain 1 - 2mpg. This only works for early 2nd gen 4Runners with the mechanical speedo (90, 91, very early 92's)
I will start with the '98 4Runner 4x4 Auto ecu because thats what I have.
There will be no time frame in completing them and I'll not be responsible for you destroying anything on your vehicle. These will be a guide only, educational purposes, and there may be mistakes. You follow them at your own risk. Sometimes color of wires on the vehicle differ from that of the FSM. I have no way of checking out those anomalies.
Sure, send it. I'll take a look. I can also compile a list of wires changed for same ecu type but different years.
I'm surprised no one has jumped at this offer.
