Mystery wires. Help please.
Old Mar 28, 2008 | 05:50 PM
neoworm0's Avatar
Any one know what this red and green wire used to be connected to? This is the wire harness that goes to the tranny etc. on a 2000 taco motor. Much appreciated.[IMG][/IMG]
Old Mar 28, 2008 | 06:06 PM
RobD's Avatar
Auto or manual?
Old Mar 28, 2008 | 06:11 PM
neoworm0's Avatar
manual
Old Mar 28, 2008 | 06:34 PM
RobD's Avatar
I have two guesses, and remember that these are only guesses, but it could be either your back up light switch or your transfer case 4wd engagement switch.
I can't find either colour in my 1997 Tacoma wiring diagrams.
Old Mar 30, 2008 | 08:27 AM
jasond's Avatar
On a 4wd, manual t-case (not push button) 2000 taco those two wires are most likely the wires going to the ADD indicator switch. Should be a green wire with a black stripe and a red wire with a white stripe.
If you are hooking up your 4wd light, you should have a plug for the t-case that has a red with white stripe and a white with a black stripe. For your 4wd light to work you will need to connect the green wire with a black stripe and a red wire with a white stripe together as it is in series with the other switch for the t-case.
Before you connect those two wires together, check and make sure that it is the same wire at the switch on the t-case and where your harness is cut (the red wire with the white stripe) with an ohm meter.
Old Mar 30, 2008 | 07:20 PM
neoworm0's Avatar
Thanks.
I crawled under a 97 today and had a look and it definitely goes to the ADD indicator switch. Thanks for the instructions on hooking it up.
JonG85
Jan 18, 2023 04:31 PM
shooter86314
Jan 7, 2016 07:05 AM
tshort48
Sep 27, 2015 01:04 PM
ToyotaMD
Sep 22, 2015 04:49 AM
themightykhoner
Sep 18, 2015 02:28 AM
