3.4 clutch to 3.0 flywheel?
Old Apr 21, 2008 | 07:30 AM
Mise's Avatar
OK, got a 3.4 from an auto 4Runner, gonna mate it to a R150 manual. I've been researching this quite a bit. I know that the normal/best route would be to get a 3.4 flywheel, clutch and pilot bearing and use a 3.0 pilot bearing. The 3.0 cluth could also be used, but it's smaller, right? The tranny has the shorter input shaft.
What differences are there between the 3.0 and 3.4 flywheels? Could I just drill the 3.0 flywheel to accept the 3.4 clutch? I could get a 3.0 flywheel _much_ easier and cheaper than a 3.4 flywheel, but I don't like the idea of a smaller cluth than original. I also have very good possibilities to do the machine work myself, so it won't be a problem. Are there any gothchas in this plan?
- Mise, Finland
Old Apr 21, 2008 | 05:34 PM
RobD's Avatar
There is a reason it's a bigger flywheel.
Just go with the 3.4 clutch and flywheel, the 3.4 pilot bearing, and the 3.0 throwout bearing and be done with it and never have sleepless nights regarding your tranny.
Old Apr 21, 2008 | 08:16 PM
Mise's Avatar
OK, thanks. That's what I'm trying to find out. It's a bit confusing as I've gotten the impression that the flywheel (at least the ring gear) diameter has to be the same, if the same starters and bellhousings fit them both.
The clutch mountings and possibly some other minor mods would be easy to do, but if the flywheels are too different, I'll just have to source a 3.4 flywheel. The closest ones available will be in the US, I guess.
Old Apr 21, 2008 | 09:15 PM
Albuquerque Jim's Avatar
You can get a 3.4 Flywheel for $110 at Napa.
Old Apr 21, 2008 | 09:19 PM
RobD's Avatar
Where are you located?
Old Apr 21, 2008 | 10:43 PM
Mise's Avatar
Finland. Not many gas Runners around. Some 3.0 stuff is available, but my 3.4 has been the only one I've seen for sale in years.
Old Apr 22, 2008 | 12:43 PM
JGrund85's Avatar
I got my flywheel from autozone for 68 bucks plus a core charge. You probably don't have autozone in finland though
Old Jul 15, 2008 | 12:28 PM
agusgus3's Avatar
what about using a 3.0 flywheel/clutch/pilot bearing combo on a 3.4 crank mated to the original 3.0 5spd?
jb
Old Jul 15, 2008 | 07:24 PM
odonekanobe's Avatar
That is what I did to mine. It worked out good, and I was able to get a centerforce dual friction much cheaper than a 3.4. But is it not as strong?
SubiKing
Aug 21, 2021 03:57 AM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
Sep 4, 2015 09:27 AM
93toyoguy
Aug 2, 2015 07:41 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
