used motor 3.4 compression ??
Old Mar 11, 2009 | 09:09 PM
cadi_daddy's Avatar
i am looking at buying a 3.4 from a local yard to preform the swap. i was told that the motor was compression tested and the results were 150- 180. the donor is a 98 4runner 4x4 AT with 136,000 miles. if i can get it complete for $900 would that be a good buy?
Old Mar 11, 2009 | 09:34 PM
904_runner's Avatar
I bought mine out of a 99 tacoma.
Has 130,000 miles on it out of an auto. Pulled the motor myself.
Got mine for $800..
Old Mar 11, 2009 | 09:48 PM
cadi_daddy's Avatar
so what about the compression results. are they good and within specs?
Old Mar 11, 2009 | 09:49 PM
904_runner's Avatar
Those are good number.
Id be more concerned about them all having the SAME compression... I was told the cylinders could be within 10% off but no more..
Old Mar 11, 2009 | 09:56 PM
cadi_daddy's Avatar
ok thanks man
Old Mar 12, 2009 | 08:12 AM
neoworm0's Avatar
An answer like "the compression is between 150 and 180" would lead me to believe the guy doesn't actually know what the compression is or can't remember. There is a big difference between 150 and 180. Especially if there is that much difference on the same motor. Check it yourself to be sure.
Old Mar 12, 2009 | 11:57 AM
syber_kowboy's Avatar
neoworm0 is correct. Double check the compression yourself and look for variation. The compression should all be pretty close to each other. Maybe 10-15 psi difference between the highest and lowest, and they should all be above 150 or so.
Old Mar 12, 2009 | 12:15 PM
Richjrosa's Avatar
This is straight out of AllData.. a very cool diagnostic program we use. Ideal cylinder pressure is above 174 psi minimum should not fall below 145 psi and the difference between top and bottom readings should be less than 15 psi. I hope this helps.
Rich
Old Mar 12, 2009 | 06:59 PM
cadi_daddy's Avatar
thanks for the advice so far guys. i bought the motor and will have the mechanic at my work "leak" test it tomarrow. based on the compression results that were done today by my guy, so far it sounds like it will be the ONE.
Flying91
45
Apr 11, 2024 04:39 PM
okamikai
Apr 30, 2018 10:19 PM
93toyoguy
Aug 2, 2015 07:41 PM
thefishguy77
Jul 30, 2015 10:59 AM
94whiterunner
Jul 12, 2015 07:15 PM
