3.4 missing part.. engine to trans peice
Old Jul 14, 2009 | 03:37 PM
TatonkaII's Avatar
I bought an 99 3.4 and trans as a package and I am missing a part.. or two.
I've got it all mocked up but realized I have now way to bolt the bottom of my trans to my engine. I'm missing whatever that part is.. what is it and where can I find it??
Without knowing what it is or what ist called.. finding this picture is the best I can do. (sorry to whomever owns this pic.. but thank you!)
Attached Thumbnails 3.4 missing part.. engine to trans peice-missing-part.jpg
Old Jul 14, 2009 | 04:11 PM
dntsdad's Avatar
there is a gusset that goes there and under by the oil pan that straps the two together. One for each side..
Nevermind its junk without those. You should sell it to me!!!
SHould be an easy junkyard part to find.
Old Jul 14, 2009 | 04:18 PM
dntsdad's Avatar
Old Jul 14, 2009 | 04:19 PM
dntsdad's Avatar
well that pic doesnt help much.....hopefully you get the idea
Old Jul 14, 2009 | 04:50 PM
TatonkaII's Avatar
Got it..can you email that to me so I can get a better idea?
cmanning3547@yahoo.com
Thanks!
Old Jul 14, 2009 | 04:52 PM
TatonkaII's Avatar
never mind, got it
Old Jul 14, 2009 | 05:42 PM
904_runner's Avatar
got the pics or the parts?
I reused my 3.0L brackets.
Old Jul 15, 2009 | 02:22 PM
TatonkaII's Avatar
I'll get a pic later on if I can, I'm not able to go to the shop. Right now I've got it all bolted up abut there is a opening/gap on the bottom right of the trans/engine which I assume is covered by the bracket on that side. I dont have either driver/passenger side bracket.
Thanks,
Chuck
PS: if anyone has them, thatd be awesome.. but it doesn't seem like this would be something "laying" around..
Old Jul 15, 2009 | 02:24 PM
904_runner's Avatar
don't you have the ones from your 3.0L? if you did a 3.4L swap from a 3.0L you can reuse those brackets.
Old Jul 15, 2009 | 06:21 PM
TatonkaII's Avatar
No, I'm the idiot who is swapping one in his 1985 22R equipped vehicle. I have NO earthly idea WTF i am doing.... and loving every minute of it. My brother talked me in to it and a week after the engine got here he skipped town and got a job out of the country...SO, i'm learning as I go.
Old Jul 15, 2009 | 07:41 PM
904_runner's Avatar
Well This is a really helpfull link:
http://www.andrewzook.com/
What transmission are you using?
Old Jul 16, 2009 | 11:35 AM
JonnyBoy's Avatar
You know, those guys are optional. They weren't on the 2000 3.4 and tranny I got either, and I didn't put them on cause I was too lazy to clean the gunk out of the unused threads in the block.
Old Jul 16, 2009 | 04:02 PM
TatonkaII's Avatar
Well, my engine 99' and I am using the stock 5sp from the Tacoma with it. I got an adapter from Marlin and am using my duals behind it.
Here is a pic of where she sits:
Old Jul 22, 2009 | 12:46 PM
Ahbustae86's Avatar
I am doing the same swap and using a 98 3.4 and auto tranny. I also thought I was missing the stiffener brackets, but the Toyota dealer told me he doesn't see it on their computer so it probably doesn't need them. I also checked the Bellhousing and look like there isn't a hole to bolt that bracket to. I'm still researching it and may modify the 3.0 to fit the 3.4.
Old Aug 10, 2009 | 09:44 AM
TatonkaII's Avatar
Guys- I finally got my hands on the brackets and it looks like either they are they wrong ones or its not what i need.
I have a fairly large gap (plenty big enough for mud, small rocks, etc. to get through) from the bottom or my engine to the bottom of my manual trans. I thought maybe the brackets would over up the opening, but they don't. I'm going to fab up a small piece of sheet metal to cover it up and bolt that directly to my trans to keep stuff out. I just wanted to let everyone know in case someone else was wondering.
Old Aug 10, 2009 | 11:27 AM
yodathespian87's Avatar
Are you missing the very small steel sheet that goes in between the trans and the engine? That would keep all of that out and is down there. Hard to tell with out good pics.
Old Aug 10, 2009 | 11:47 AM
cadman's Avatar
There is also a rubber seal that goes on that cover.
Old Aug 11, 2009 | 10:15 AM
Ahbustae86's Avatar
You are looking for the rear engine cover that goes between the lower part of the engine and bellhousing. Those brackets are on the 3.0s I believe and not required on a 3.4. If I remember correctly on the 3.0's the brackets are used to hold the rear engine cover plate in place where the 3.4 it is held in place by the bell itself. Toyota has those plates for under $30.
Old Aug 11, 2009 | 05:14 PM
TatonkaII's Avatar
ok, thanks guys. I'm down south so mud is inevitable.. I'll swing by toyota on order one. Does anyone have a part number by chance?
Old Oct 7, 2009 | 02:43 PM
TatonkaII's Avatar
I hate to start a NEW thread for one silly question, but I have one:
what does this go to? I figured to would goto the EVAP box, but I couldnt figure it out.
Any help??
http://thumb10.webshots.net/t/65/765...0hzWKUk_th.jpg
