wire harness?
Old Oct 4, 2009 | 08:37 AM
sinneDBTB's Avatar
wire harness?
bought myself a 3.4 to swap my 3.0 got the 3.4 m/t ecu wondering if i can make a auto wire harness work? been researching the site with no definitive answers... anyone know?
Old Oct 4, 2009 | 09:32 AM
sinneDBTB's Avatar
bump*
Old Oct 4, 2009 | 08:59 PM
Eat_at_Joes's Avatar
what type of trans are you going with behind the 3.4 after its installed? If its a manual with a manual ecu with a auto harness then i think that you could make it work. i beleive that the a/t harness has more wires sense the computer has more to monitor but if you can sort out these wires then you may be set.
now if its the a/t behind the 3.4 with the a/t harness and a m/t ecu then it will not work.
again im not for certain so do not qoute me. but it sounds logical to me.
Old Oct 4, 2009 | 09:13 PM
904_runner's Avatar
Yes you can make it work..
My truck was originally a 3.0L, 5-speed.
Donor motor was a 99 tacoma auto.
I used everythign from the donor and made it work with the auto ecu and harness.
So to answer your question, YES you can make it work, just takes a bit of time and research..
I just jumped the park/neutral saftey switch to make the ecu think it is in neutral the whole time..
Runs fine!
Old Oct 4, 2009 | 11:01 PM
sinneDBTB's Avatar
its a 90 3.0 5spd swap with a 99 3.4 5spd (not complete) but i also scored a complete but disassembled 97 3.4 auto. so my plan is to use the 99 5spd since it is newer has less km and mostly since its assembled. i want to use the 97 for parts, mostly the exhaust and wiring harness on the 99. follow? i wasnt able to get the ecu i wanted so no i have the option open to get either. so which would work better? the 97 a/t or the 99 m/t?
Old Oct 4, 2009 | 11:37 PM
904_runner's Avatar
i would use the 99 mt personally..
What was not complete about it?
Old Oct 6, 2009 | 04:21 PM
sinneDBTB's Avatar
the 99 didnt have a alt, p/s, wire harness, ecu...
but what i meant is what ECU will work best with 99 m/t engine and 97 a/t wire harness?
i want to keep my swap as cheap as possible so lil bit of extra work is no issue.
Old Oct 6, 2009 | 04:59 PM
Jody's Avatar
I think you'll end up wanting to use the ecu out of a 97 m/t. I did mine with the 3.4 and harness from a 98 a/t 4runner but used the ecu from a 98 m/t tacoma. everything works fine. it's a bit of a pain to wire up the back-up lights, 4wd sensor but your speedo should still be a cable. I just cut all the plugs off for the a/t and grafted on the plugs for a 3.0 m/t and made everything line up at the jumper.
Good Luck
80Truck
Oct 12, 2025 07:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TDonkey
Jul 26, 2015 10:14 AM
toofly1999
Jul 25, 2015 07:09 PM
msane99
Jul 17, 2015 10:13 AM
