Harness and ECU compatability
Old Feb 3, 2010 | 12:11 PM
Okiyota's Avatar
What year harnesses still work with which year ecus?
Would a 2002 manual wire-harness work with a 2001 manual ecu?
Old Feb 23, 2010 | 02:16 PM
el_taco's Avatar
well...don't quote me but...
from my extensive "research"...and personal experiences...
i've found out that you should match year-to-year trucks, such as 2001-2001 and 2003-2003 and blah blah blah.
on the other hand...if you have a 2002 taco manual ECU and/or harness on hand and don't need it...i can take it off your hands. my junk is bad.
good luck.
Old Feb 13, 2016 | 04:06 PM
cap85's Avatar
I bought a JDM 3.4 engine and the type of Toyota it came off of is unknown, could be from a Tacoma or 4Runner etc. also, the year of the engine could be from a 1997-2002
It is an automatic engine and I'm putting it in my 1993 4wd ext cab SR5 manual pickup
I am trying to find out how much the years vary when it comes to the ECU, I have been searching everywhere for this info and can't find it or I'm just not good researching
Any help is greatly appreciated
Old Feb 13, 2016 | 04:50 PM
donomite49's Avatar
ORS Offroad Solutions has some info on there site. They also have a online question link.
He is a toyota master tech.
Old Feb 13, 2016 | 05:01 PM
cap85's Avatar
I have emailed and called and it's hard to get him to reply but I know he is the master!
Old Feb 13, 2016 | 05:15 PM
donomite49's Avatar
Ors site in the installation instructions.
I'd get a harness and ecu from a 99 or 2000 runner, it has supercharger compatible capabilities, just have to get the same year afm.
Old Feb 14, 2016 | 11:51 AM
wyoming9's Avatar
Red face
I know your really meant MAF sensor instead of AFM
Old Feb 14, 2016 | 12:19 PM
donomite49's Avatar
Yes I stand corrected.
Old Feb 15, 2016 | 08:49 PM
SacRunner's Avatar
The blocks are essentially the same from year to year, model to model (including US vs JDM markets); the big differences are going to be electronics.
Find a handful of sensors that have the 10-digit part number on them (XXXXX-XXXXX) then type them into Google, one at a time, then try to find a "where-used" list of all the applications where that sensor is used. The more sensor part numbers you look up, the closer of an idea you should have when trying to identify where your engine came from.
If you can't seem to have any luck with that, then go to your local junk yard and see if there's an intact engine harness and ECU you can buy together as a "package," look up the application of that ECU, then start buying compatible sensors for that ECU and convert your JDM motor to match the ECU.
Old Feb 16, 2016 | 04:16 AM
cap85's Avatar
Thanks for the info
I found a couple ECU's from 96 and will look up the numbers
1uzRunner
63
Nov 10, 2018 03:58 PM
tshort48
Sep 27, 2015 01:04 PM
irv
Sep 23, 2015 08:30 AM
Hugh_Mann
Sep 16, 2015 03:59 AM
zz_denis
Sep 6, 2015 03:43 PM
