3.4 off to a rough start need advice
Old Jun 17, 2010 | 09:12 PM
just call me smithy's Avatar
well i started my 3.4 swap yesterday, before swapping my 3.0 out i had a list of things i wanted to replace on the 3.4
1 timing belt
2 water pump
3 belts
4 vale gaskets-the old ones were leaking and oil was everywhere!
5 rear main seal
6 cam seals
7 timing belt bearings
8 and some other various seals
this all was going well till lunch time when i realized that i pretty much have the whole engine apart why not save myself a head ach down the line and change the head-gaskets now.
so i started to remove the crankshaft bolt and it wont budge....tried my impact at 150psi and with the pulley holder (this is where it happened) i acteuly broke..more like fractured the crank pulley right where the two pegs go in to it!!!!!!!!!!!!!!!
i was like dang(sorry for my language i do apologies) now im at a stand still
my first question is dose any one have a trick to get the crank pulley off without using the holder on it?
and my second one is can i use my 3vz crank pulley as a replacement?
Old Jun 17, 2010 | 10:43 PM
NIGHTCRAWLER541's Avatar
If it aint broke dont fix it. 3vz and 5vz crank pullys are not the same. I like to chain up the flex plate to keep the engine from rotating.
Old Jun 18, 2010 | 12:04 AM
vital22re's Avatar
totally a bro
you can get a flywheel holder and have some hold that while you get that crank bolt. No worries though... i did the same thing too..
Old Jun 18, 2010 | 01:50 AM
are you sugesting that i dont do head gaskets?
Old Jun 18, 2010 | 02:59 AM
dose any one have a harmonic balancer for sale?
Old Jun 18, 2010 | 05:56 AM
theMonch's Avatar
Hang in there.
Don't worry about it, I did the same thing too. I wound up drilling a piece of 1/4" bar stock to bolt to the back of the crank and block to keep the crank from turning then ratchet strapped the motor on the stand to my 4runner's bumper to stabilize it. I then was able to get it off with a breaker bar and an extension pipe. They are tight on there, but they do come off.
As for the headgaskets, I wouldn't bother if the motor is not really high mileage 200,000 +. Toyota puts em' together really good from the factory, you shouldn't have a problem. I would to the timing/waterpump, etc.
For a replacement harmonic balancer...
https://www.yotatech.com/forums/f160...71/index2.html
check Post #36 of my swap thread. user "Greg Canada". He just offered one to me a few days back and I would assume he still has it. Great price too!!
Old Jun 20, 2010 | 05:46 AM
ok so ive been working on the 3.4 for the last few-days, i have it to the block, head are cleaned and im ready for reassembly, a few quick questions
1 im going from an auto 3.0 to a manual 3.4 i have two manual trans( the one that came with the 3.4 and one i bought to work with my ifs) and saw on the 3.4 trans that there was an extra censer on it . for those who have done a manual swap can you shed some light on the tranny wiring?
2 also ive been researching on how tho change the crossover. my question is can i run this engine with duel pipes that never x? or is there not enuf back presure?
Old Jun 20, 2010 | 08:16 AM
dntsdad's Avatar
I would ren a crosover somewhere. The one from toyotaswapsonly.com is probably the way to go if you cant weld and fabricate.....like me.
SO you have two r150's? A 3.0 one and a 3.4 one? Which one are you going to use? I may be interested in the 3.4 one of you are selling it for cheap
Old Jun 20, 2010 | 08:36 AM
dntsdad's Avatar
http://www.ttora.com/forum/showthread.php?t=159443
Old Jun 22, 2010 | 09:16 AM
hay im stuck on this tranny wiring dose any one have a diagram of how thy mated the 3.4 to the r150?
Old Jun 22, 2010 | 09:22 AM
dem0nk1d's Avatar
toyonlyswaps.com
ask for cliff. you'll send out your stock x-over pipe And they will send it back to you cut and flipped. This is the route I went, I could have had my local welder/muffler guy do it up, but I think Cliff and the guys use a mock up so you know the fit will be perfect.
I think full cost is around 120 bucks or so.
Old Jun 22, 2010 | 10:33 AM
I'm able to do the welding with no problem. My question was, can I run dual straight pipes? Or is that not enough back pressure.
I still need help with tranny wiring. Does anyone have a diagram that I could use? Maybe a manual or something online?
Old Jun 22, 2010 | 03:57 PM
dntsdad's Avatar
what exactly do you need a diagram of? A r151F wiring?
Old Jun 22, 2010 | 08:09 PM
i believe so, like a said before the 3.4 tranny has one censer more then the r150 and i wanted to know what every one else did about that, in all of the 3.4 swaps i read through they always said it just bolts on without any problem.
Old Jun 22, 2010 | 08:26 PM
ok the 3vz is almost out if any one is in need of some good 3.0 parts let me know!!!!!
Old Jun 23, 2010 | 08:43 AM
dem0nk1d's Avatar
I'm not sure about the extra sensor. I'm using my old 92 4x4 manual tranny in my truck.
the connectors that came off of the 3.4 manual wiring is....
VSS - Speed Sensor (2 Wire) -- 3.0 VSS is a (3 Wire)
Reverse lights
I think add indicator light, which i don't have hooked up because it's quite obvious when i have the truck in 4Wheeling mode.
Just get the VSS hooked up if your using a manual. If you using the 3.4 tranny I'm not sure if you still use the 3.4 VSS or if you should swap it out and use the 3.0... IDK Try one method if that fails, then move onto the next VSS....
Old Jun 23, 2010 | 07:30 PM
im not using the 3.4 tranny. ill post pics tomorrow of what im trying to describe
Old Jun 25, 2010 | 02:12 PM
I'm having trouble putting the cams in the heads. I already have the FSM and I'm still having trouble. Does anyone have any suggestions or experience?
Old Jun 25, 2010 | 09:15 PM
ok so i think i have them in right but im not sure, ug time for more research
Old Aug 1, 2010 | 05:11 PM
i haven't had to much time to post pics or do a wright up as go along with the swap, but i will once im done, but now that im to the wiring part i dont know how to go any further...
i have downloaded the diagrams from tis and it just looks like gibberish, can some one help me to the right direction the motor is out of a 96 4runner 4x4 manual, and its going in to my 91 4runner with a 3.0auto, any help would be appreciated.
