3.4 off to a rough start need advice
#41
Um, what dash harness?
Your '91 still has the harness that terminates into two plugs behind the passenger side kick panel, correct?
You need to splice your '96 engine harness into those two. Leave the rest of it alone.
#42
You are going to use those two plugs I showed you when I was there getting the tranny. Everything, except the COR relay, is in there that you need to hook up to.
You do not need to change any fuse panels.
Run your own wire from the starter relay into the kick panel and join it with the STA wire from the 3.4 ECM and the larger starter wire in the 3.0 kick panel B/W i think or something like that.
I am back in town after a week in the mountains so give me a call if you need to. I called you back last week but left a message because I was headed back into the mountains after coming into a small town with service to grab some groceries.
Regency
20
Jan 3, 2020 07:43 PM
Vargntucson
Jul 4, 2015 12:15 PM
