89 pickup 3.0 to 3.4
Old Apr 12, 2010 | 08:54 PM
a3racekarts@hotmail.'s Avatar
so i got this truck for 1500, pulled the engine 1 seized piston (#4) and one spun rod bearing (#5). im tryin to decide between the swap or stay stock. i want to do it. i just don't wanna do all the work and then not be able to get it smogged... booo CA... i read alot of projects but not so much about the SMOG portion... just looking for some advise, or if its worth it... thanks
Old Apr 12, 2010 | 09:50 PM
dntsdad's Avatar
Search smog, ref, emissions, etc. and you will find tons of info.
Here are a few to get you started. As always, there is no better info than that you receive FROM YOUR LOCAL REF. Go talk to him and he will set you straight.
https://www.yotatech.com/forums/f160...splant-143516/
https://www.yotatech.com/forums/f160...ex-cab-196823/
Old Apr 15, 2010 | 06:21 PM
thanks, will do... i am $100 short, and taking the test from being SMOG certified... so im pretty sure if you modify the engine in ANY way (even CARB legal stuff) that the ref wont pass it, so the problem i was curious about was what do i do about the exhaust, mainly the crossover tube, can i make the stock 3.4 exhaust dump work W/O custom tubing? and what side do they normally (stock) collect on? 3.0 is drivers side... 3.4 pass???
Old Apr 15, 2010 | 08:54 PM
dntsdad's Avatar
you cannot modify it so no custom tubing will be allow before the factory last cat.
3.0 dumps drivers side, 3.4 passenger
Old Apr 17, 2010 | 10:29 AM
so, can it work... should right?
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Roger Borba II
Jul 9, 2015 05:05 PM
Cplmike
Jul 8, 2015 08:47 PM
