28 pin plug
Old Jun 25, 2010 | 01:30 PM
84Prerunner's Avatar
28 pin plug
Im missing the 28 pin plug for my 97 ECU. i know this is the plug where most of the wire swapping goes on. does anyone have a part number or know if the plug can be bought from toyota? i have search all the yard near by and haven't found any that fit. The 3.0 plugs are different then what i have.
Old Jun 25, 2010 | 01:46 PM
dem0nk1d's Avatar
Read my post...
https://www.yotatech.com/forums/f160...tumped-211013/
Old Jun 25, 2010 | 01:54 PM
what post? i had read all that before i posted this, did you ever solve it? like i said i havent been able to find one at the local junkyards.
and mine does use the same multi row plugs like yours.
Old Jun 25, 2010 | 02:01 PM
dem0nk1d's Avatar
yeah i had to go to a non-pick your part junk yard, it was about 20 bucks....
http://www.ih8mud.com/tech/pdf/WireH...l/femaleno.pdf
SEARCH FOR "90980-11218"
that should be the plug you need.
Old Jun 25, 2010 | 02:08 PM
thats the plug, thank you.
ill check some other junkyards tomorrow.
Old Jun 25, 2010 | 02:25 PM
just called the local toyota dealer, $18.32.
has anyone bought it from the dealer? any problems getting the pins in or anything spliced together?
Old Jun 25, 2010 | 05:29 PM
dem0nk1d's Avatar
id try to find one at the junk yard with wires attached.. but it is what it is... hard to find.
nvdesertrunner
May 11, 2020 08:18 PM
TJWilly
Jul 31, 2015 02:05 PM
keithporter83
Jul 18, 2015 12:37 PM
msane99
Jul 17, 2015 10:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
