Question on 3.4 swap?
Old Oct 2, 2009 | 10:08 AM
94runner4RJ's Avatar
Question Question on 3.4 swap?
Sorry for the long post but need some info on 3.4 swap. Ok, every time there is a problem with a 3.0 most say to swap it out with a 3.4...so I have a 94 runner with a bad 3.0 and could do the swap but my hesitation is that from what I have read you have to "modify" cut the hood or install a body lift in order to get the hood closed...cause the 3.4 sits to high in the engine bay. Am I the only one that thinks this is a clear sign you should not be swapping this motor in?
Has anyone completed this swap in California and cleared a safty inspection and smog with this set up?
What about resale value?
Thanks for the info in advance!!
Old Oct 2, 2009 | 11:26 AM
cadman's Avatar
You guys seriously need to search a little better. There is an entire forum dedicated to the 3.4 swap HERE
Lots of info there. Read through first, then ask away.
Old Oct 2, 2009 | 09:18 PM
BIG RON's Avatar
[QUOTE=94runner4RJ;51242957]Sorry for the long post but need some info on 3.4 swap. Ok, every time there is a problem with a 3.0 most say to swap it out with a 3.4...so I have a 94 runner with a bad 3.0 and could do the swap but my hesitation is that from what I have read you have to "modify" cut the hood or install a body lift in order to get the hood closed...cause the 3.4 sits to high in the engine bay. Am I the only one that thinks this is a clear sign you should not be swapping this motor in?
Old Oct 3, 2009 | 12:53 PM
Tragic Drive's Avatar
Old Oct 3, 2009 | 04:21 PM
RobD's Avatar
Small hole and some wiring is worth the effort to do this swap.
Yes, it's worth it.
Don't care about resale. Keeping it for as long as I can.
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
94whiterunner
Jul 12, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
