Question on 3.4 swap?
Sorry for the long post but need some info on 3.4 swap. Ok, every time there is a problem with a 3.0 most say to swap it out with a 3.4...so I have a 94 runner with a bad 3.0 and could do the swap but my hesitation is that from what I have read you have to "modify" cut the hood or install a body lift in order to get the hood closed...cause the 3.4 sits to high in the engine bay. Am I the only one that thinks this is a clear sign you should not be swapping this motor in?
Has anyone completed this swap in California and cleared a safty inspection and smog with this set up?
What about resale value?
Thanks for the info in advance!!
[QUOTE=94runner4RJ;51242957]Sorry for the long post but need some info on 3.4 swap. Ok, every time there is a problem with a 3.0 most say to swap it out with a 3.4...so I have a 94 runner with a bad 3.0 and could do the swap but my hesitation is that from what I have read you have to "modify" cut the hood or install a body lift in order to get the hood closed...cause the 3.4 sits to high in the engine bay. Am I the only one that thinks this is a clear sign you should not be swapping this motor in?
Flying91
45
Apr 11, 2024 04:39 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
