removing pins from the connetors
Old Oct 2, 2009 | 05:36 PM
BIG RON's Avatar
what are you guys using to remove the pins from the connectors?
i'm having no luck trying it my way.
Old Oct 2, 2009 | 05:54 PM
RMA's Avatar
RMA
I had a small screwdriver that I had to grind on all 4 sides until it fit in the hole for the pin connector . oh but it was for a 1uz swap not 3.4 , should work the same though.
Old Oct 3, 2009 | 01:18 PM
BIG RON's Avatar
guess it helps to unlock the connector.
Old Nov 5, 2009 | 10:20 AM
667.tech's Avatar
Man im having the same problem n i got the connector unlocked. didnt have any prob getting pins out until I started the ecu plugs man they are so little.i havent got any yet I just sprayed some contact lube that i use for my crossfaders on my mixer. hopefully it will help.
Old Nov 5, 2009 | 04:22 PM
dntsdad's Avatar
Snap On make a small kit to take those pins out of factory plugs.
SnapOn is pricey and hard to locate unless you have a regular truck but I am sure that other tool companies sell the same thing.
Old Nov 9, 2009 | 07:52 AM
667.tech's Avatar
Yea I finally got all my out took alot of practice and the ecu plugs from my 02 donor suck no matter how great u are. took me about a day to learn to properly unlock and pick them but now I'm a plug removing fool. unpinned the whole 3.0 harness for practice. good stuff guys. I used a bobby pin for most of the smaller connectors eventually my fingers got sore so I went to the 99 cent store and got a small screwdriver set and went to town on em on the bench grinder.
Sean McAuley
9
Nov 8, 2015 12:26 PM
old87yota
Sep 9, 2015 12:39 PM
JAmdor3
Aug 11, 2015 10:53 AM
TJWilly
Jul 31, 2015 02:05 PM
crashburnoveride
Jul 10, 2015 06:39 AM
