Almost Running
Old Mar 6, 2010 | 05:29 PM
sam4runner's Avatar
Almost Running
Alright so i have the motor in and everything pretty much hooked up. I also have the vitals wired up, EFI, COR, Ignition, Starter. I have power to the ignitor and all the plugs.
So it will crank over but no start. I tried alittle starting fluid and it fired up for a sec, so maybe not getting fuel but i have fuel coming out of the return line pretty steady.
Does anyone have any ideas on what i am missing?
Also is the fuel pump supposed to come on with the key and stay on? Because i can only hear it turn on when i put the test light in the connector and it bridges or jumps it i really dont know then i will turn on but still no start.
Thanks in advance.
Old Mar 6, 2010 | 07:49 PM
whokrz's Avatar
Not sure what you are working on but if the air flow meter plugged in?
Old Mar 7, 2010 | 12:18 AM
sam4runner's Avatar
Okay so here is where i am at. The starting fluid did not fully start it just combusted a bit. So i have concluded that i am getting fuel fine. ( i removed the main supply and fuel is coming?
The new problem is no spark. The test light shows no power to the plugs, I also took the plug out and rested it against the block and nothing. Where does the power come from that goes the the coil packs? Would it be a wire in the body harness? other than the B-R IGN wire?
Or does anyone have any other ideas why i am not getting spark? everything is grounded. I read somewhere that it could be the crank not tighten down enough? anyone experienced this? I did do the timing belt so maybe a possibility ?
Thanks for everyone's help
2000 3.4 manual into a 91 4runner also manual
Old Mar 7, 2010 | 06:52 AM
GJCruiser's Avatar
I had a similar problem. For me, there was power to the ignitor, however there's one more splice to be made which also powered air flow, O2 sensors, etc. It was called B+ and was white w/blue if I remember.
Old Mar 7, 2010 | 07:32 AM
dntsdad's Avatar
Agree with above and also make sure that you have a GOOD ground to the mounting body of the ignitor. I used a small wire wheel on a drill to take up all the paint and then bolted that sucker down tight. If you have any dialectic grease, use that as well.
Old Mar 7, 2010 | 05:50 PM
sam4runner's Avatar
Thanks GJ and dntsdad. That was definitely it. I hooked up that wire and if fired right up. It will only go for about 5 seconds but i don't have more than half the wires hooked up yet. So that is my task for tomorrow. Thanks again
Old Mar 7, 2010 | 07:59 PM
dntsdad's Avatar
right on good to hear. Let us know how the rest goes.
Old Mar 7, 2010 | 11:13 PM
sam4runner's Avatar
After i am all done i will post my whole build, but i really appreciate everyone's input and help.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
