3.4 auto to manual swap info??
Old Apr 14, 2010 | 11:10 PM
stockwell45's Avatar
Im looking for some info on 3.4 auto to manual tranny swaps. maybe a writeup by someone thats done it or something? Ive searched here, pirate, google, and I got absolutely nothing. theres gotta be some info out there. anybody know anyone whose done it?? any info would be great. thanks
Old Apr 14, 2010 | 11:54 PM
jskijoe's Avatar
I don't have a writeup yet but I did my swap with a 3.4 from a 98 2wd 4runner. I used a 97 Manual 4x4 computer to put into my 91 manual V6 4x4 truck. ORS did the harness but the rest was from help from this site. Still doing some final tweaks but so far so good!
Old Apr 16, 2010 | 10:14 AM
ok thats good to hear. does anyone know how to tweak the auto ecu to make it work with a manual?
Old Apr 16, 2010 | 11:08 AM
Ride4Fun's Avatar
I have just (well almost) completed this swap myself. I am running a 97 auto ecm/harness in a 93 manual. So far eveything is running fine. I will know more this weekend once I have finish wiring in my OBD2 plug and checked for codes. However, codes for the ecm looking for the auto trans. does not concern me as much as it will you with you being in CA, emissions aren't as tough on the east coast.
I am currently cleaning up my wiring layout (it is in an excel file) and as soon as I have proven everything out, I would be glad to share if it will help.
Old Apr 16, 2010 | 11:26 AM
awesome that would be great! Im not too concerned about the CEL being on for right now, my main concern is just getting everything to work normally
Old Apr 17, 2010 | 06:15 AM
dntsdad's Avatar
looking forward to hearing how this goes as well. I have my auto running fine but thinking of going back to manual before I buy my adapter from MArlin.
Old Apr 17, 2010 | 08:25 AM
ok I now know mostly everything I need for this swap, I just have 2 more questions:
1. is the crossmember for the auto tranny the same as the manual tranny?
2. I read somewhere that I need to take my flywheel out of my auto tranny and put it in the new 5 speed. I dont know why I would need to do this but is this true?
Old Apr 17, 2010 | 04:22 PM
Old Apr 18, 2010 | 08:31 AM
dntsdad's Avatar
Look here. I dont think so and Slater documents various part pretty well. I had to use the manual crossmember and weld a piece on it to mount the mount if that makes sense. Basically extend the crossmember's mounting surface forward about 3-4 inches.
https://www.yotatech.com/forums/f116...89-4x4-104219/
For the life of me I cant understand this at all. An auto uses a flexplate and a manual a flywheel. You should need nothing from the auto. I have read that they use different length bolts so you may want to grab a set from Toyota for a manual vehicle if you dont have them from a manual
Post your results as to trouble codes!!
Old Apr 18, 2010 | 07:46 PM
Thank you so much dntsdad that thread has loads of info that will help me. I emailed a guy that has done this before and I'm just waiting for him to reply back. As of right now, the only thing I have for the swap is the manual tranny and t case. Everything else I need to track down and buy. So It may be a while before I have everything I need to finish this. Money is also tight at the moment, so I may have to wait for a few more paychecks to come in to be able to get everything. But I shall keep you posted and hopefully before long I'll be grabbin gears in my 5 speed
Old Apr 20, 2010 | 06:24 PM
Does anybody know anybody who has done this to a 3rd gen before? ive emailed some one person who never wrote me back and the other 2 emails of other people didnt work. just need to find out some more little stuff. any info would be great. even if you know somebody who knows a friend of a friend...that would work too!
Old Apr 21, 2010 | 04:55 AM
Ride4Fun's Avatar
Sorry for the delay on the results of the codes, but it has been really busy since last week and I haven't been able to get back to the 4Runner. Hopefully I will have some results soon and I will post them up then.
Old Apr 21, 2010 | 12:59 PM
ok thanks a bunch! its not a huge rush I still need a lot more info about other things before I can even begin
Old Jun 29, 2010 | 07:47 AM
Runnerfan's Avatar
I put the 3.4 and 5 speed trans from a 96 4runner in my 92 4runner that had a auto trany. But mine was quite easy because the motor and trany were already paired from the 96 with the ECM. But you do have to make a bracket for the trany mount to extend it forward. I also used a marlin crawled adapter plate with a gear driven t-case from a 4 cyl. pickup, but drive lines and everything went right in.
Old Jun 29, 2010 | 12:07 PM
danthemanx07's Avatar
There is probably a better place to post this question since it sounds like you are only looking to swap the tranny, not the engine. See my thread here:
http://ttora.com/forum/showthread.php?t=159482
as I think it is more along the lines of what you are looking for.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
KBar
Jul 13, 2015 06:01 PM
94whiterunner
Jul 12, 2015 07:15 PM
Cplmike
Jul 8, 2015 08:47 PM
