Final preperations
Old Oct 3, 2009 | 05:24 PM
Eat_at_Joes's Avatar
Final preperations
As of now my dream is on its way to becoming true but i still have some minor concerns with this swap.
I own a 1993 p/u with a 3.0 in it now with a 5 speed pullin up the rear. i found the donor truck with a 3.4 with only 22,000 miles(thats typed correct) the truck is a 1996 tacoma crew cab with a auto tras behind it.
My questions are
1)will 3.4 headers clear the frame of the 93 truck? (not to be confused with the stock manifold)
2)is it really that simple?
thanks guys
Old Oct 4, 2009 | 07:07 AM
BIG RON's Avatar
headers will clear. yes, its not that bad.
Old Oct 4, 2009 | 09:45 AM
Sweet. coming from the 3.0 im not a fan of having that cross over anymore. If anyone has any idea where i can pick up a manual harness and ecu would be very useful. if some has this and needs a auto harness and ecu maybe a trade?
Old Oct 5, 2009 | 07:55 AM
BIG RON's Avatar
you have a pm.
Old Oct 5, 2009 | 01:36 PM
Tragic Drive's Avatar
Originally Posted by Eat_at_Joes
My questions are
thanks guys
What headers are you going to use?
Downey's fit but its tight.
Old Oct 6, 2009 | 07:25 PM
A New High's Avatar
2) Define simple.
The fitting of the engine and accessories is simple; the wiring is not.
It's intimidating at first, but if you're patient and have time to really dig into the EWD's- or have experience reading EWD's- it's doable.
I'm in the middle of trying to figure out the wiring, and I'm gonna be honest, it's pretty frustrating! I believe you'll need more than just the engine harness. On the 3.0, all the plugs at the ECU went to the engine, where as with the 3.4, only two plugs go to the engine. Two plugs that go to the ECU come off the dash harness, and one was for the security system or something. I say this cause you might need the dash harness as well.
That's not even getting into the big dash harness-to-engine harness plug...
Old Oct 6, 2009 | 07:30 PM
A New High's Avatar
Oh yeah, my truck is a 92 auto, and my donor is a 99 manual. I've already converted the truck to manual.
Also, I read in quite a few places that the swap can be done with only splicing 6 wires or so- the rest of the wires can be swapped by switching the pins in the plugs around.
So far, by the way two on the ecu plugs are tangled into the dash harness, I don't see this being possible, but we'll see
Old Oct 6, 2009 | 07:31 PM
A New High's Avatar
Old Oct 6, 2009 | 08:15 PM
No i cant use downeys because the last i heard was he shut down so as of now im hunting for a good pair but kinda turnin my wheels here. i did alot of research on the 3slow but never was thinking that my opportunity for the 3.4 swap would come around so quick. long story short (i know i ask alot) but what header system for the 3.4 would you guys recommend.
Still tryin to get my s#!t in a row so any help would be great.
Old Oct 6, 2009 | 08:21 PM
Originally Posted by A New High
2) Define simple.
I mean as simple as a engine swap can be for a efi engine. sad thing is i know that all the wiring going to be the hardest, longest, and most tedious part but i can and will do it for that extra power!!
Davebarbier
Nov 3, 2015 03:28 PM
scott90
Oct 4, 2015 09:21 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
tylermx71
Sep 29, 2015 08:49 PM
