O2 Sensor Questions
Old Oct 18, 2009 | 06:12 PM
LukaDuke15's Avatar
O2 Sensor Questions
I have a truck that I am swapping a 3.4l into. I am running true dual exhaust so there is no Y-Pipe or catalytics converters. Do I need to run two O2 Sensors? and if i do where would be the best place to find them for good price?
Old Oct 19, 2009 | 05:52 PM
lbhsbz's Avatar
The ECM uses one sensor to adjust the fuel trims for both banks. If you only run one sensor, it's input will only come from one bank. I would try to run an X-pipe at least and put the sensor there, but it's got to be pretty close to the heads...I'd say not more than 2 feet downstream or else the readings may be screwed up. For the post cat sensor, you can get one of those simulators that they sell at jegs.
Why not run a single exhaust? This ain't a small block chevy, it's a toyota.
Old Oct 19, 2009 | 06:52 PM
LukaDuke15's Avatar
Thanks for the info. I was going to run the single exhaust but the crossover pipe would not fit because of where the motor is mounted. I also have not seen a truck that runs true dual exhaust so i wanted be unique and see how the truck runs and sounds.
Old Oct 20, 2009 | 04:08 PM
lbhsbz's Avatar
I'll take some pics of my setup tonight...I made the crossover come underneith the bellhousing.
I've also got a set of Downey headers for sale if you don't feel like building stuff.
Old Oct 22, 2009 | 09:33 AM
LukaDuke15's Avatar
Very cool I'll take a look tonight. Another question if I'm not running a catalytic what should i run for an after catalytic o2 sensor because it wont read a difference because there is no cat. So should i run two of the pre-catalytic o2 sensors or should i get an o2 sensor simulator and run an after catalytic sensor?
Old Dec 20, 2009 | 06:22 PM
Ocean Racer's Avatar
I would like to know where to get the Sensor simulator??
Old Jul 5, 2012 | 07:55 AM
aferg's Avatar
Sorry to dig up the old thread...
I'm now thinking of not using the behind the engine cross over, however placement of the first O2 sensor in my design would only be reading the 3 cylinders on the drivers side. Is that really a big problem? (95 T-100 ECU, with 2nd O2 sensor simulator)
Thanks!
Old Jul 5, 2012 | 08:58 AM
Marley2984's Avatar
http://www.urdusa.com/
krimsonone
Sep 13, 2024 09:33 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Gevo
Jul 29, 2015 11:15 AM
nonstop
Jul 24, 2015 06:29 PM
88yodabasket
Jul 13, 2015 01:32 PM
