What hood scoop & where to cut?
Old Jan 30, 2010 | 06:40 PM
Innocent Fool's Avatar
Looking to get a hood scoop put in for a 3.4 swap.
- Anyone know what scoop works best & where to get it?
- What are the measurements for cutting the hole into the stock '90 hood. (going from 3.0 - 3.4, no body lift, no S/C). Want to get the scoop in before I start the swap. Does someone have a pattern mabey?
Old Jan 30, 2010 | 06:52 PM
Tofer's Avatar
Sponsor
i just put spacers at the hinges... it doesnt look bad at all.
heres what it looks like during the day and with the hood closed.
all said it cost me 8 bucks for the spacers and the longer bolts.
Old Jan 30, 2010 | 08:12 PM
TatonkaII's Avatar
LOL, I'd skip the spacers idea and go with a hood scoop. I don't think there are any "measurements" out there, but maybe someone does. Any reason you have to do the scoop first? Besides the cool factor, I'd just wait till you do the swap. Otherwise, your stuck looking at pictures and guessing.
Old Jan 30, 2010 | 08:13 PM
Tofer's Avatar
Sponsor
the 3.4 is taller than the 3.0..
Old Jan 30, 2010 | 08:19 PM
TatonkaII's Avatar
Yes, I know. But he was asking where the 3.4 hit BEFORE he does his swap. I'd assume he wants to do this for looks/practical reasons and if that is the case a hood scoop would look a lot better than what you did. So, what's your point?
Old Jan 30, 2010 | 08:28 PM
Tofer's Avatar
Sponsor
sorry miss read what you asked... i thought you were asking why he was putting on the hoodscoop at all. i agree, if you're going to cut and scoop it, do it after the swap.
Old Jan 30, 2010 | 11:11 PM
olharleyman's Avatar
1"-2" body lift will clearance the 3.4 as well no need to cut the hood that way or like I am looking at a Chevy Cowl full length scoop 1 1/2"-2" tall will give the to cool factor and the clearance for the 3.4 plenum
Old Jan 30, 2010 | 11:51 PM
vital22re's Avatar
totally a bro
correction you need atleast 1.5" to properly clear the hood.
Old Jan 31, 2010 | 08:36 AM
cadman's Avatar
My hood clears with only a 1" bl, and that includes using new motor isolators.
Old Feb 5, 2010 | 04:38 AM
yodathespian87's Avatar
I have a hood scoop on mine. When I did the swap it barely rubbed. Still in the process of bondoing mine.
Old Feb 5, 2010 | 11:48 AM
mt_goat's Avatar
X2, plus I have a SC. I did remove the insulation and cut some of the back bracing out though.
It makes a difference what year truck you have too.
Old Feb 9, 2010 | 10:28 AM
skunkwhat's Avatar
I did the spacer hood mod, same as above. Used some 3/8 nuts and longer bolts. had everything laying around. No cutting, no painting, no bl. And it helps to pull air out of the engine bay.
Old May 12, 2010 | 12:17 PM
dem0nk1d's Avatar
I used three 1/4 washers stacked on each side of the hood. A total of 12. So 3 washers stacked on each bolt. Also used longer bolts.
I have not even cut the hood bracing out, or do I have a body lift.
Stock 92
Old May 26, 2010 | 02:53 PM
Ahbustae86's Avatar
Stock 92
Clean job on that swap.
88sasturbotoy
Jan 30, 2026 01:57 PM
g3bill2
Aug 7, 2015 07:04 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
