Clutch issues
Old May 20, 2010 | 03:49 PM
dem0nk1d's Avatar
Clutch issues
So I went with using all 3.4 clutch parts minus the 3.4 throwout bearing, which i'm using a brand new 3.0 throwout bearing. My question is now, that i have the slave cylinder bolt up to the tranny, i have notice that it is compressed with the "ram rod" full compressed into the slave cylinder, and the fork is all the way forward. I've bleed the clutch cylinder a few times with my mighty vac, and still can't it to build up pressure. Also shouldn't you be able to move the fork towards the rear of the truck by hand? Or am i thinking about it wrong?
Old May 21, 2010 | 07:01 AM
dem0nk1d's Avatar
Okay got the clutch work. I guess I had a massive air bubble in the system. It took a longer time than usual to bleed the system by myself. Now that I got that squared away, i'm trying to do the research on the COR. Do you have to use the 3.4 Relay, I've found tons of talk on 3.0 vs 3.4. But nobody really has a fix for using the 3.0's
Old May 21, 2010 | 03:23 PM
dntsdad's Avatar
check evoltra's thread for using the 3.0 COR relay.
In my opinion its just too easy to use the 3.4 relay. Its such a simple design that you could essentially use any old relay from any car audio/security shop.
Old May 21, 2010 | 04:29 PM
dem0nk1d's Avatar
i might go that route.
Old May 22, 2010 | 11:16 AM
hamish_18's Avatar
hmm didn't really have a problem with mine. just basically don't use the wire that goes to the old MAF sensor. Thats basically the only difference.
jasonty
41
Dec 23, 2018 01:00 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
