clutch kit
Old Mar 8, 2010 | 12:25 PM
mechaniman's Avatar
clutch kit
Ok, so I have my 3.4 ready to go in, seems like everyone says to use a 3.4l clutch kit.and a 3.0 throw out bearing. but what if I'm using the flywheel off the 3.0. .do I just use the 3.0 clutch kit.
hoping to install motor tomorrow, this is my last step.
Old Mar 8, 2010 | 08:48 PM
mechaniman's Avatar
damn, looks like I've had 40 people view this post but no replies...
the reason I'm asking,, I went to mount my 3.4l clutch to a 3.0l flywheel, the alignment dowels don't match up and neither did the bolt holes. I know it seems like a no brainer, just use the 3.0 clutch because you already know it bolts to that flywheel.
I'm just looking to hear from someone who has done it, before I get parts delivered and have to send those back too.
thanks y'all
Old Mar 8, 2010 | 09:06 PM
Matt90V6SR5's Avatar
Like to help u out man,but I got no experience.One of these guys in here has the right answer for you,hang in there.Good luck.
Old Mar 9, 2010 | 04:46 AM
yodathespian87's Avatar
I have heard of guys using a 3.0 clutch kit and everything worked for them. Personally I went with the 3.4 flywheel and kit and just used the 3.0 throwout bearing. I do know the 5vz and the 3vz have different flywheels. On a Lexus 1uz forum they were talking about the thickness of them. If I can find it I will add it later.
Old Mar 9, 2010 | 04:47 AM
Wavephf's Avatar
I used all of the 3.0 clutch parts and it works great. 3.0 flywheel, disc, pressure plate, throw out. I guess the difference is the 3.4 clutch has a bigger surface area so it grips better. the ring gear is the same diameter I believe so you can use either one
Old Mar 9, 2010 | 05:30 AM
dntsdad's Avatar
I am not sure about your question since I used the auto but keep in mind that you will probably want to stay with the matching starter for whatever flywheel you use.
Old Mar 9, 2010 | 05:47 AM
jskijoe's Avatar
my understanding is that you can use either starter on either flywheel. I went with the 3.4 starter and replaced the contacts. I also went with the 3.4 clutch and flywheel but have heard of people going all 3.0 but I think there are key differences that make the 3.4 setup better like greater clutch surface area for better grip.
smthwsn357
May 1, 2024 07:28 AM
dumpster84
Apr 30, 2016 06:03 AM
smithyboy69
Nov 28, 2015 04:13 PM
Sep 4, 2015 09:27 AM
norcal98
Aug 10, 2015 06:20 AM
