o2 sensor wiring... can't find them...
Old Jun 11, 2010 | 01:51 PM
dem0nk1d's Avatar
okay i'm missing something from somewhere on my swap. i thought the o2 wires would be apart of the speed speedo loom.
Old Jun 11, 2010 | 01:52 PM
dem0nk1d's Avatar
i also thought the two blue connectors was the o2 connectors but that's not correct.
Old Jun 14, 2010 | 08:24 AM
mechaniman's Avatar
On my swap the plugs were called h3 and h4 on the control unit EWD's. four wire plugs, of course the scrap yard cut that part of the harness off mine.
Old Jun 14, 2010 | 08:54 AM
dem0nk1d's Avatar
yeah i found them this morning. they got cut off. i'm wondering where i can get the plugs from. Which other cars use the same 4 wire plug.... This could be the easiest solution, because finding 3.4 trucks at the local pick your parts are next to impossible.
The rear i will just run the o2 emulator/bypass.
Old Jun 14, 2010 | 01:18 PM
mechaniman's Avatar
I ended up soldering in my rear one.
Old Jun 15, 2010 | 08:31 PM
theMonch's Avatar
Can be ordered seperately
You can get them at the dealership. They carry the most popular ones (like the o2) in stock usually. Take a look at this link, you will prob be looking for female waterproof if memory serves.
http://www.ih8mud.com/tech/WireHarnessRepairParts.php
Old Jun 16, 2010 | 12:14 AM
vital22re's Avatar
totally a bro
most o2 connections are the same.. steal them from your 3.0 harness. I also used my transmission harness section from the 3.0 since my transmission is the same one and just soldered it in.
Old Jun 16, 2010 | 11:27 AM
dem0nk1d's Avatar
that connector page is pretty darn good to have. but i think i'll head out to the junk yard and grab the plugs with a little wire attached.
thanks guys...
OMG work is so boring today I would love to have a nice cold quality beer.
Old Jun 16, 2010 | 11:47 AM
mechaniman's Avatar
the 3.0 o2 sensor plugs are not the same, I tried that too.
Old Jun 16, 2010 | 12:20 PM
dem0nk1d's Avatar
probably need to knock out some kind of plastic tab out of the 3.0 harness connector. IDK
Old Jun 22, 2010 | 02:25 PM
dem0nk1d's Avatar
Note that I went to the junk yard and nabbed two o2 sensor connectors, and the fit perfectly. So they should be the same. As long as it's a four wire o2.
sandyota
Feb 4, 2021 11:16 AM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
bryan34w
Jul 6, 2015 05:53 PM
