22 lifers per 100km
Old Dec 18, 2017 | 12:34 PM
Scotttekoch's Avatar
22 lifers per 100km
91 pickup
96 3.4 auto harness
98 auto ecu
R150
ORS harness to make “˟˟˟˟”
“Work right”
4:10
305/70r16 A/T. (32.7”)
Only CEL’s are
Shift solenoid (x2)
Tranny temp sensor
Evap purg ( took whole ˟˟˟kin thing out)
The 3 evap sensors are still plugged in
No cat
2 o2 sensors hooked up
Truck weighs 2200kg
125km/
4th gear
3600ish RPM
Flat ground
No wind
My fuel consumption is ˟˟˟king unbelievably horrible
22liters
To travel 107km
Somebody out there encounter this???
This can’t b normal!
Yes .. I know 5.29’s would b beneficial
( that’s coming end of January)
And...
If I plug in a scan tool that has live engine monitoring..
Engine load seams very hi.
Even at a idle
Old Dec 18, 2017 | 12:36 PM
I was told that the 98 3.4 had different injectors then the 96
could the b the cause???
Old Dec 19, 2017 | 12:06 AM
wyoming9's Avatar
Red face
What do you mean Engine Load seems High??
Just how are you figuring out your mileage ??
Have you done a average of several trips??
If I did the math correct just guessing that is close to what I get .
What is the history of the engine fresh rebuilt all new parts ??
Used engine of unknown miles ??
Then with the 2 senors in the exhaust you no doubt might be confusing the ECM with no cat
You would also be getting a Cat code at least one.
Could your harness be messed up it is if your still getting auto tranny codes
I am hoping you live with no emission inspections
Poke Runner
72
May 5, 2006 03:43 AM
magil
13
Sep 16, 2003 06:11 AM
