22 lifers per 100km
91 pickup
96 3.4 auto harness 98 auto ecu R150 ORS harness to make “˟˟˟˟” “Work right” 4:10 305/70r16 A/T. (32.7”) Only CEL’s are Shift solenoid (x2) Tranny temp sensor Evap purg ( took whole ˟˟˟kin thing out) The 3 evap sensors are still plugged in No cat 2 o2 sensors hooked up Truck weighs 2200kg 125km/ 4th gear 3600ish RPM Flat ground No wind My fuel consumption is ˟˟˟king unbelievably horrible 22liters To travel 107km Somebody out there encounter this??? This can’t b normal! Yes .. I know 5.29’s would b beneficial ( that’s coming end of January) And... If I plug in a scan tool that has live engine monitoring.. Engine load seams very hi. Even at a idle |
I was told that the 98 3.4 had different injectors then the 96
could the b the cause??? |
What do you mean Engine Load seems High??
Just how are you figuring out your mileage ?? Have you done a average of several trips?? If I did the math correct just guessing that is close to what I get . What is the history of the engine fresh rebuilt all new parts ?? Used engine of unknown miles ?? Then with the 2 senors in the exhaust you no doubt might be confusing the ECM with no cat You would also be getting a Cat code at least one. Could your harness be messed up it is if your still getting auto tranny codes I am hoping you live with no emission inspections |
