Please help- 3.4 swapped questions!
Old Feb 13, 2023 | 09:26 AM
crane-op.1's Avatar
I have a 89 p/u 4x4 that I bought already swapped to 3.4 from the 3.0. It needs a new clutch put in it, but I have no idea what trans I have. I can’t find an Id tag or numbers anywhere. It’s a 5 spd manual. I was told the 3.4 came out of a 2000 Tacoma. Any ideas on how to identify??
Old Apr 27, 2023 | 05:25 AM
Boredmuse's Avatar
Should be a R150
Old Apr 27, 2023 | 02:43 PM
akwheeler's Avatar
If the 89 was born a 5 speed it should have the original transmission.
Old Apr 28, 2023 | 06:33 AM
rattlewagon's Avatar
Marlin has a pretty handy transmission guide
https://www.marlincrawler.com/transmission
Old Apr 30, 2023 | 07:13 PM
aztoyman's Avatar
I would say to not order a clutch until you pull the one you have. The reason being is there could be either a 3.0 or 3.4 clutch used. It might be the 3.0 since that was the original engine but you don't know for sure.
I went from a 22RE with a W56B to a 3.4 engine, 3.4 flywheel and clutch, 3.0 R150 bellhousing to a R151F transmission and used the slave cylinder, fork and TO bearing from my original 88 W56B.
Better to verify before you order any parts. Good luck with your project.
Tilikum102602
93-98 T100s (Build-Up Section)
May 24, 2017 10:01 AM
Tiletony
3.4 Swaps
Nov 11, 2016 09:39 AM
Squishy!
Mar 2, 2010 02:28 PM
