Help! No Crank after swap!
First attempt to start after swap, cranked for about 1 second then stopped. 1999 3.4 4Runner Manual into 90 3.0 Pickup Manual. I ran from cab plug C1 STA wire to the starter and trigger and to ECM via plug E14 STA.
Now the truck will not crank. The IGN fuse is fine, but there is no power to trigger wire. Possibly Starter relay?
Please let me know if anyone has had this issue. I searched and read a bunch of others but the only thing I can think of is possibly the 99 was a limited and has security system. But if that was the case it wouldn't crank in the first place right?
No change after battery disconnected.
Thanks,
Ian
Thanks,
Ian
Please disregard, post can be deleted. Starter solenoid wire (trigger wire) plug on starter must have got damaged during the installation and is loose. It must be loosing contact or shorting inside. Fiddle with it and it works.
Sorry for the panic post.
Ian
Ian
5.9ford
12-06-2012 05:20 PM
peterng
02-26-2006 06:42 AM
