88 motorhome 22re to 5vz
Old Aug 25, 2019 | 04:12 PM
darkprairie24's Avatar
Did a 3.0 to 3.4 swap 2 years ago in my 88 4runner. Easy. Now I have a 88 Toyota motorhome I really want to swap- but it’s a 22re auto. My issues is the transmission - cross member is welded in - so does that mean in need to cut it out and weld in a 340 transmission cross member ??? My welding is basic at best so if i have to cut and refab a cross member that puts me out is the running on this swap- any insight or other threads I can be directed to is appreciated.
Old Aug 25, 2019 | 08:00 PM
Co_94_PU's Avatar
Probably...
The motorhome chassis were modified by the coach builders.
I feel pretty confident in saying they didn't do anything they didn't have to so the captive nuts are probably in there somewhere still since they are internally located inside the frame rails and would have been a big waste of time to remove.
That said "it's just a transmission mount", if you can get the transmisson relatively close to centered a blind guy can weld it in..
Old Aug 26, 2019 | 08:31 AM
old87yota's Avatar
The Toyota 2WD chassis had the transmission cross-member welded in from the factory.
I am not sure where the A340 transmission mounting spot will end up, but it will probably need to be moved.
Sorry I am not much help here...
jordan.covey94
Jan 11, 2016 07:14 AM
mutt
3.4 Swaps
16
Apr 7, 2010 01:25 PM
Rpulignaoffroad
May 26, 2009 03:52 PM
farmboy
Jan 19, 2007 02:01 PM
GTE4runner
28
Mar 29, 2005 08:43 AM
