Replaced throttle body, now have a very annoying humming noise
Old Sep 2, 2020 | 03:12 PM
moto809's Avatar
5 Year Member
I completed my 3.4 swap a few weeks ago, and due to a high idle issue I have been driving around with the IAC plugged off. Instead of getting a new IAC valve, I decided to buy a used throttle body off ebay (only $40 more than the IAC alone) since I wanted the cruise control pulley as well. (my JDM only came with throttle and transmission pulleys.)
Well, today I got the new TB installed, and the truck idles like a champ now. BUT, now there is a severely annoying humming sound coming from the throttle body. The frequency of it is absolutely unbearable in the cab.
I took a video trying to capture the sound, does anybody have any ideas? A couple hours of this while wheeling would drive a person mad.
Old Sep 2, 2020 | 05:07 PM
moto809's Avatar
5 Year Member
Sorry I can't seem to figure out how to upload a video. yotatech says it's too big and filesharing says invalid address. I'm stumped.
Old Sep 3, 2020 | 10:00 AM
moto809's Avatar
5 Year Member
Ok here's a youtube link to the video. Any help appreciated.
Old Sep 3, 2020 | 10:08 AM
Co_94_PU's Avatar
You're missing atleast one vacuum line cap, right on top of the TB. One of the ERPG lettered lines. Probably it's other end is open also..
Old Sep 3, 2020 | 10:13 AM
moto809's Avatar
5 Year Member
I must have knocked it off when I installed the TB, I didn't even notice. I'll pull one off the old one. The other one that is open under the plenum is just a pipe that goes nowhere, its open on both ends, just in case anyone else sees that.
What is ERPG by the way?
Old Sep 3, 2020 | 03:01 PM
moto809's Avatar
5 Year Member
Ok I plugged it off again, but nothing changed. What do you mean “the other end”. I don’t see anything else to plug off.
Old Sep 4, 2020 | 04:03 PM
moto809's Avatar
5 Year Member
Anybody else run into this? I used a new gasket when I swapped the TB...
One thing to note, the noise doesn't appear until the engine hits operating temp and the idle settles all the way down.
Old Sep 4, 2020 | 05:37 PM
Co_94_PU's Avatar
Try capping off those ICS water ports you're not using, you could have a bad seal in there (which is maybe why you bypassed the water passage here?)
Old Sep 4, 2020 | 07:27 PM
moto809's Avatar
5 Year Member
I didn't bypass anything... I'm not sure what you saw there.
Everything is hooked up where it should be.
Old Sep 19, 2020 | 06:17 PM
moto809's Avatar
5 Year Member
No ideas?
Old Oct 1, 2020 | 04:05 AM
92-5vze's Avatar
What EVAP system are you running? I am going with the charcoal canister (thought I could see it in your video) but I have heard rumors that it makes an obnoxious noise on 3.4 swaps.
Old Oct 1, 2020 | 08:12 AM
moto809's Avatar
5 Year Member
Interesting...
I am using the original 3VZ evap canister. However, the noise seems to be dead center of the throttle body. I'm starting to suspect the IAC since the noise doesn't exist until the engine hits operating temp.
kyle9013
May 5, 2012 08:26 PM
fireyota
Jan 27, 2010 05:25 AM
Cuthroat72
Sep 22, 2009 08:30 PM
