View Full Version : Engine Swaps
- Opinions/Ideas on 87 4-Runner Engine Swap (Toyota or Domestic?)
- Engine Swap 1kzt into hilux pickup-need advice
- HELP-86carb motor to a 87 efi truck
- wiring help please
- just did 350 swap, power steering problem
- 383 to stock 22re?
- 22re engine swap wiring and computer
- Radiator with outlet/inlet both on passenger side?
- vortec v6 or sbc v8 1st gen 4runner
- 22R to a 327. Here we go...
- 4.3 swap help!!!
- 3.0 5sp swap to 2.7 witch bell housing ?
- MR2 motor in a toyota 4x4
- 90 to 90 Manual to Auto 3.0L swap
- 7mge swap done in 94 toy pickup
- Anyone make swap harness for the supra motors?
- '91 3.0 V6 for a '92 3.0 V6
- 1992 22re in a 1988 Truck with 22re
- 82toy w/350chev header???s
- Death Rattle... and an interesting idea?
- 1985 toyota 4x4 22re,5 speed. in CA. what type engine should i put in ?? ideas?????
- 3.slow spun bearing...straight swap or "?"
- 1988 22re into a 1986 truck?
- 4AGE 20v Swap into Corolla All-trac
- has anyone done a ford 302 and t5 swap into a pickup?
- anybody else used downeys 4l60e adapter?
- 1992 engine swap options - 5.3, 3.4, 4.3?
- swap 22re for turbo
- 5MGE swap/ inline fuel pump recommendations?
- 3.0 to 3.0 swap - Wiring
- Chevy Auto Tranny with 350 in 94 4Runner
- 4.3 4runners pics please
- 350 sbc swap help
- bored out 3.0
- 1994 toyota PU engine swap(87 chevy auto)
- Need 4.3 vortec swap into 91 pick up info!!!
- W56 stock clutch
- 91 tranny and 3.0 7mge
- Reputable Engine Shop?
- 327 swap what tranny?
- 5VZFE Long Block Suppliers
- engine swap
- 1990 3vze in a 1995 4 runner?
- 94 3.0L 4Runner would like information on V8 or V6 Chevy or Toyota swaps
- 22re compatible with 7mgte auto tranny?
- 2L setting in the mounts
- 81 4x4 swap to rte
- Pre-purchase swap questions:
- 90' 22re to 86' 22r3
- 22re into an 82? or 22re to 22r
- can i switch my 89 22re to carbourated to fit in an 81?
- tundra body swap or 1uz-fe swap???
- 4.0L into 3rd Gen 4runner
- 3.0 to 4.7 swap?
- changing my mind on engine swap! 22re to 7m
- Unhappy with my 22re
- 85 22re t0 86 turbo swap
- 3vze to 22re
- i want to swap out with a 3.0 in with a 22 re
- wiring
- Transmission Compatability?
- 1GR-FE swap
- 2001 yota chevy 350 and axle swap
- 1992 turbo 22re swap injector problems
- 22re to 22re help!
- HELP! Power Loss after Swap
- 2.7 coil pack motor into current 2.7 distributor motor help needed
- subaru powered yota?
- 2006 toyota tacoma
- LS1 yota
- 22r in volkswagen bug?
- 1981 toyota engine swap.
- 81 Celica Supra 5ME swap into 87 Pickup??
- VQ35DE 3.5l Nissan v6 engine in a 95 4runner
- 7mge in pickup
- 3.0 toyota for 289 engine swap
- need help 22r swap
- toyota celica engine in an 86 truck
- 1986 sr5 turbo engine questions
- need help, 1990 3.0L to a 22re
- buick 350 swap
- Anyone in Vegas buy a half cut from G Speed Corp?
- 83 Toyota 250 conversion. Need some help please.
- 22re
- 83 toyota chevy 350 swap need some input please
- 84 22r into 88 runner
- 22re and 22rte block?
- i wanna hot rod a 98 4 runner 2wd auto with a carb'd v8 crate...
- 94t100 4x4 engine swap
- 7mge swap problem
- your opinions requested: new 22re or used 3rz?
- 2 engines left out in the cold.
- I6 Jeep engine
- 22RE or W56 bolt pattern diagram?
- V6/V8 swap that requires less than 1inch body lift
- 2000 long block into 1998
- Best Engine Swap?
- 22re???
- 7m swap in my 94
- 1uz-fe or sc 5vz-fe
- mid 90's toyo pickup and 2jz engine swap
- t100 engine swap or not???
- 5.0 swap
- 4.3 engine swap on a 91 4runner
- 22r to 22re head ache help?
- What Engine?
- em-4 simple digital systems
- 22r swap
- sbc engine swap
- question about jeep 5.2 v8 into my runner
- 1985 4x4 PickUp Work Truck Swap Options...
- Blew up the motor in my 92 pickup
- different oil pan?
- 1987 extra cab 22re auto tranny motor swap
- 1rz-e to 3vze swap
- Where to source OEM electrical connectors?
- 22re to 22re??
- 1998 auto 2wd 3.4, need info on v8 engine swaps?
- 22re to v6?
- have 22re truck bought 22r engine to replace
- engine swap suggestions ???
- 20r to 22re swap HELP!!
- 350 swap ?
- need help for a new power plant
- help with engine swap
- 3800 V6 Buick into 3vze runner
- need info on swapping 4.3 into 82 toy
- small block chevy 350 in 95 toyota tacoma
- 1 jz tt
- 89 22re out and in with 92 v6?
- curious on a engine to put in my toyota pickup
- Tranny Strength
- 4.3 chevy swap relay buzzing while off battery dead
- possibility of nissan ka24de swap
- 7mge oilpan
- 22re swap
- 1987 Toyta pickup. motor swap 2.4 for 4.3
- cheap 22re supplier
- 1998 4.3 SPI with 4l60e swap.
- 350/350 turbo in 83 toyota
- 2.4 to 2.7 engine swap
- question about tranny to tcase adapter
- 84 22r swap into 88
- Engine + Tranny swap
- Motor swap help???
- 3.0 v6
- what is a good radiator when doing a 350 swap
- 3.4 starts then dies
- 22re rebuild?
- 91, 3.0 eng. swapp.
- 4.8 GM 4l60e swap w/ toyota t-case
- Engine Swap. Which is better? Gas or Diesel
- all swaps and costs
- What engine would you put in your truck and why?
- 3VZE to SR20DET swap?
- What is necessary to put a 5VZ in my in my 2.7 equipped 97 Taco?
- Help with a auto to manual swap
- Most economical (initial cost & mpg) 1989 4Runner swap?
- 350 crate motor into my 85' Yota
- 2.7 to 22re??
- 3.0L Engine swap
- '95 3VZE replacing '92??
- engine installation
- 350 info im new to the yota thing
- 89 4runner from 3.0 to 2.7 can it be done
- Should I ????89 2wd 22re with only 55,871 miles on it
- 5 speed 1998 swap?
- 4.3 question
- Best swap for a an older Toyota truck
- is the flex plate the same from the auto 3.0 2wd and the 3.0 4wd
- 3.4 swap into 86 pickup
- Front Cross member pictures
- 4.0 VVTI swap to replace 3.SLOW
- 302 swap into my 86 p/u
- new 3.0
- got a tranny question
- mopar 318 swap?
- Vortec eletrical help
- 93 V6 into 90 4cyl. 4Runner
- fj40 engine swap
- your thoughts on a 5.0
- 350 swap without the 350 trans???
- Subaru Boxer in my First Gen!!!
- what would be a good engine choice
- Swap Redirect
- 1988 efi to 1986 carb possible?
- Possible '92 3.0 to Chev 350 swap
- 4.3 swap;)
- How about a 3.4 swap into a 94 1 ton
- Rotary engine?
- 22RE Harness Question
- 22r-22ret??
- 4.3 into 83 yota few questions
- 3.0 to chevy 350 swap
- 22RE Runs (Codes 3 & 7)
- Highlander hybrid motor in 1st gen 4runner?
- 22R EFI Swap Need Help(No Fuel)
- Need help with sb ford swap
- 7mge swap
- Aristo Water Pump/Hydro Fan
- 4.3 in IFS no body lift allowed is it possible
- swap 3vze for 22re in 94 pickup
- rebuild 22re or engine swap
- 20r to 22r swap cluster help?
- what engine to swap????
- 2l-t turbo diesel into a 1985 4runnner??
- 1JZ GTE VVTi but 4WD
- oil pan and motor mount issue
- New 22re Short Block
- Supra motor swap
- 94 t100 3.0 to 350 swap????????
- dose anyone kno where i might be able to get a set of motor monts for a 351 swap
- 88 Toyota 1UZ Swap plus MORE!!!!
- Mustang 4.6 DOHC Swap - Reasonable?
- Anyone in northwest want to do a supra swap?
- Chevy 4.3l engine into 1990 4runner - Looking for Advice, Engine, Parts
- 22RE powered Buggy! EFI harness built from scratch!
- 20r to a 22re swap. need all the help i can get
- efi mtor to carb setup swap
- 88 4wd to 92 2wd swap
- 1993 toyota t100 2wd to 4wd
- what Rad for a 5.0 swap
- sbc swap in 89 yota, lift???
- 22re to 2jzge or 7mge
- 231 buick swap
- ever replaced a rod bearing in the vehicle?
- What Year 22re Do I need for a '94?
- 91 4Runner SBC swap
- 85 4runner 350 700r what radiator
- '82 20r in to a '89 4x4 w/22re
- v8 in my v4 89 Toyota
- 22re into 80 pickup
- Couple questions on the 4.3 swap
- 302 wiring
- Need a new engine
- 85 too 90 22-RE
- 99 yoda getting old.... curious about swaps
- 99' chevy v-6 vortex engine swap for 83' yoda4x4?
- 2rz swap in a 86 ifs 22re 4runner help!!!!
- Lots of questions, need some advice
- Swaps that work with 4x4 IFS and stock height
- 22r HELP! will they all fit?
- Please help, need good referee CA
- 22r engine swap wiring
- NEED HELP 22RE to 22R
- Stupid noob needs help.
- 85 22r into a 90 efi body
- 1999 3.4l in a 1993 x-cab problems
- 87 4runner getting a newish heart, what trouble should i expect?
