Engine Swaps Swapping an engine in your Toy, here is where to learn how
3vze to 22re
Old Apr 27, 2010 | 02:45 PM
JAH ARMY's Avatar
3vze to 22re
i have a 90 single cab 4x4 with the 3vze and the motor is going..i dont want to waste money fixing this motor so i want to go with the 22re...i know i need motor,trans,transfer case,ecu,harness,motor mounts etc
but i was wondering how difficult this swap is and no im not going with the 3.4 cause i dont have that kind of funds
Old Apr 27, 2010 | 03:00 PM
toyota4x4907's Avatar
And swapping in a 22re is cheaper? Can you weld? can you do wiring? Do you have tools? 22r(e)s are not without problems. They are just easier to work on.
Old Apr 27, 2010 | 03:02 PM
JAH ARMY's Avatar
i have a buddy who can help...and for the welding part isnt that just for the mounts??? if so that going to be pretty easy..i wouldnt have made a post but i've been searching alot and i havent found much info
Old Apr 27, 2010 | 03:09 PM
92 TOY's Avatar
this is something i may be contemplating also...so i am watching to see what the responses will be.
good luck.
Old Apr 27, 2010 | 03:17 PM
JAH ARMY's Avatar
thats true too toyota 22re's have there problems but i would rather invest money into a 4 banger cause its easier to work on parts are very easy to find an i would rather have a 4 banger then a v6 which also has its problems...idk im just looking for some other things i may run into aino the welding is for the mounts because the re sits more foward then the v6 is there any other welding required???and wiring i know u have to re wire everything like in any other motor swap
Old Aug 17, 2010 | 12:38 PM
86mixBreed's Avatar
wow no one has responded to this.. i just joined today because I am going to put an 85 2wd pick-up 22-re into a 88 4runner that has a blown 3vz-e. Looks like im going into this as a free for all Lol.
Old Aug 17, 2010 | 12:40 PM
86mixBreed's Avatar
or not.. been doing alot of reading.. either its just that hard or no one cares to try.. hmm...
Old Aug 17, 2010 | 12:53 PM
vital22re's Avatar
totally a bro
most people want more power, reliability when they swap motors. A more reliable, fuel efficient and more powerful swap is the 3.4. I was able to finish mine 2100 bucks. The only welding I did was for exhuast work, as everything else besides wiring was plug and play.
Old Aug 17, 2010 | 01:40 PM
86mixBreed's Avatar
i think.. like many other have realized.. rebuilding my 3vz-e will be easier to do than putting a 22r3 in it.
Old Aug 17, 2010 | 02:28 PM
Kiroshu's Avatar
Just buy another truck or another 3.0 its not worth swaping 3VZE to 22RE. Its alot of work, time, and money....
Old Aug 18, 2010 | 02:52 PM
86mixBreed's Avatar
22re*** oops
and yea im starting to see that. im actually going to just take the r150f and t-case and put it behind my 22re and then just junk the 4runner with the blown 3.0
Old Sep 12, 2010 | 10:00 PM
cbrwags's Avatar
I have done a few of these swaps. I make my own motor mount plates. On the ones I have done the motor needs to be moved 2in forward, 3-16 x 3in plate is great. Place the motor mount on the plate drill your 2 holes then move the mount 2in forward and drill. I weld studs on the 2 inside holes to make it better, but you can just use nuts and bolts if you want. The tranny will line up but the back driveline will need to be shortend 2in. As for the wiring goes mostly plug and play, but the alternator plug will need to be changed to the 4cyl, match the colors on the wires and you are good to go. Hope this helps. Also the body harness just plugs in to the ecu for the lights fuel pump and all that, so just remove the engine harness and leave the rest...
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
