2.4 to 2.7 engine swap
I have a 1994 pick up with a 22r 2.4 4cyl would it be too much troulbe to change out for a 2.7 4cyl from a 1997 pickup .I have all parts from 1997 truck .what changes will I have to do
Think seafarenman had the 3.0 replace for a 2.7L.
Here a build link to http://www.pirate4x4.com/forum/showthread.php?t=475469
You should post introduction to yourself, welcome to YT
the exhaust routes to the opposite side, you'll need to do some wiring. pressure side of fuel line. Dont know about the a/c. Not sure about bolting up to your current tranny and the 2.7 transfer case has the output for the front drive line oposite of your currant set up. I'm not sure about the motor mounts either may be lucky and just swap the motor mounts from your 2.4.
the swap
i have a 1987 toy pickup with a 22re and an a tranns out of an 84 it has dual t cases sased 529s its how i want it i would like to do the 2.7 3rz swap im looking for parts now i have the engine but ORS is shut done for good and i need the harness or can i do the whole taco dash will it fit i also want to know if the bell housing with bolt up and motor mounts i would like to know how hard and how much time it will take to do this
heres the swap man http://bb.bc4x4.com/showthread.php?1...2.7-3RZFE-Swap i'v done twice so far only takes a few days if u got every thing
steve miller
Oct 10, 2015 01:40 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
