Engine Swaps Swapping an engine in your Toy, here is where to learn how
5.0 swap
Old Jan 22, 2010 | 08:12 AM
xman66's Avatar
5.0 swap
Has anyone done a 5.0 swap i have a 87 yota and i am not sure if i want to do a 5.0 or a 3.4 swap . I have a 5.0 motor trans wiring and computer but iam still not 100% on what i want to do ? Any info would help
Old Jan 25, 2010 | 08:37 AM
68rockcrawler's Avatar
Check out NWoffroad. They sell a lot of the parts you would need such as bellhousing and headers.
RJM has a plug-n-play wiring harness that would make wiring it up very easy (www.fordfuelinjection.com). I used their harness on a 5.0 I put in my trail rig.
Old Jan 25, 2010 | 08:48 AM
84foyota's Avatar
Check out my site for more details
funfactorfab.ca
Old Feb 19, 2010 | 10:31 AM
yotaman107's Avatar
I'm just about done with my 5.0 swap. With a 4" suspension lift, 3" body lift, bellhousing adapter and motor mounts it fit pretty good. I think if you went with the 3.4 you could get away without the lift, but if you already have the 5.0 I'd go for it..
Old Feb 28, 2010 | 11:49 AM
crzylexusdrvr's Avatar
i havent done it personally but i have a FJ40 with a 5.0L 302 in it.. i want it gone lol its just a nightmare..... i cant find much help on a new trans, tcase, drivelines, im probably searching in the wrong areas.. i mean i live in utah someone should know lol.... ive only been in this yota game for a little bit now..
Old Feb 28, 2010 | 12:11 PM
904_runner's Avatar
I was talking with some guy at school.. He had a first gen runner pretty built with a 5.0L in it.. seemed badass.
Old Feb 28, 2010 | 12:32 PM
its a bad ass setup if you can get everything to line up properly, the 5.0L i have is in there, its just the transmission that the previous owner messed up on... but it is possible with fabrication being involved...
Old Mar 15, 2010 | 06:38 PM
true_blue_hickbilly's Avatar
did you use the stock toyota transmission in your 5.0 swap?
Old Mar 21, 2010 | 11:59 AM
yotaman107's Avatar
I did because it was recently rebuilt, about 5k ago. when it goes i'll sell the bellhousing and get a bronco 5 spd and a t case adapter...when it goes... it seems to be doing pretty good right now. -- w56
Old May 21, 2010 | 07:22 AM
400yzturbo's Avatar
I did this 5.0 swap in a 86 Toyota xtra cab and it was fun if you want to stay on road. I still had it IFS and when I got into any gravel it was like a boat anchor. I had to have it in 4x4 to go anywhere. It fit okay, but you have to use an electric fan to clear and you will need a custom radiator or spend a lot to get one that will keep the thing cool. Also just a side note, the w56 tranny can only handle about 200HP before you will run into problems. If you want more info just ask. I will be glad to help if you need.
Old Aug 29, 2010 | 11:02 PM
adamsbro1's Avatar
I live in Utah as well and I know that six states does good driveline work!!
Old Oct 4, 2010 | 07:55 PM
ej1bullet's Avatar
what about the bell hausing??
Old May 18, 2011 | 03:43 AM
D.J.'s Avatar
Injected 5.0 with serpentine belt clears the rad ok in mine, just used a different fan & hub from a Range Rover V8 (with more blades and just bolts on) to bring fan further back.
Old Jun 9, 2011 | 03:13 PM
bigarms23's Avatar
since you have most of the parts for the 5.0 swap go for that just beef up your rear axle is what i read but there are alot of sites and dont us northwest offroad for adapters used advanced they are better quality and make your own motor mounts it will save you money
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
