PDA
View Full Version : Engine Swaps
Pages : [1] 2 3 4
  1. Swap - Tach inquiry
  2. 1994 22re into a 1984 4wd 22r xtracab pickup
  3. 1uz in 83 Toyota Pickup - Need Help Troubleshooting
  4. 3.0l 3vz - 3.3l f33a diesel. Possible?
  5. 2jz swap FJ50 with r150 trans
  6. '89 22r into '84 2wd pickup
  7. 92 Toyota Pick-Up 2jz Swap
  8. 3VZ to 3RZ Swap
  9. 1GR-fe + R150 into a 1998 townace
  10. 22RE timing cover
  11. Sbc 350 swap in 95 pickup wiring
  12. JDM engine swap, 2 'mystery connectors'
  13. 3.4 swap
  14. 2GR-FKS in a 89 pickup
  15. Mating 20r to 91 r150f from a 3vze 4runner
  16. 1981 Toyota diesel, engine swap to new diesel engine?
  17. 22re questions
  18. Moving to So. California w/ 1UZ Swapped Truck
  19. 1982 Pickup 22R engine swap ideas
  20. '88 4Runner blown 3VZE options
  21. Engine swap
  22. Buick Lucerne
  23. GTR35 v6 in a 1983 Porsche 944
  24. Question about machining 22re block
  25. Help me with my weekend drag racing daily
  26. Need engine advice! 22RE/22R
  27. Question on Ecu pins
  28. 5VZFE PreRunner to 5VZFE 4Runner
  29. Swap or Rebuild
  30. 96 3rzfe distributor head swap onto 2000 3rzfe block???
  31. 302 swap on r150f trans
  32. 89-94 22re engine into 1988 22re
  33. 4.3 LV3 from 2014 GMC into 87' Toyota pick up
  34. 3RZ swap crowd - I want your feedback
  35. Swap help ....please
  36. 22re & running gear into Daihatsu Rocky
  37. 3.0L to 4.3L Swap help
  38. 04 chevy 5.3l into 92 toyota pickup 4x4 with stock 5 spd
  39. Possible Swap Shells for a 1MZ-FE
  40. Issues with 1jzgte in 90 pickup 4wd 4cyl.
  41. SWAP shop in NJ
  42. cluster swap on a 87 4runner
  43. 1989 ToySR5 with 4.3L Stalls
  44. 1994 Pickup jdm engine swap
  45. 3vze Manual to Auto
  46. 1993 toyota 4x4 pickup 3.0
  47. 2jz-gte swap 1987 Toyota Turbo Pickup
  48. 1uz wiring
  49. Keeping the auto trans
  50. Best swap for 86 4runner
  51. LU3 swap questions
  52. '95 2nd gen 3vze into a '88 1st gen 4runner
  53. Corax's 1UZ VVTi 4runner swap
  54. 95 22rec into a 87 22r body engine swap
  55. 86 22re 4runner body 89 22re motor swap
  56. 3rz re-power for 87 4runner. Advice and ideas welcome!
  57. 3.0
  58. 1985 Caprice Engine Swap
  59. 1984 22r new engine swap question
  60. Does 1KZ-TE fits in 2003-2009 j120 Diesel automatique 1KD Prado
  61. 2003-2009 Prado 1KD-FTV Engine Auto, Swap to 1KZ-TE
  62. om617 swap question
  63. Frame Up rebuild with LS swap
  64. Anybody mated a current gen ecotec 2.0 turbo LTG to W56 / R15#?
  65. Does a 22re bolt into a 1976 hilux
  66. 5.7L Tundra V8 swap - 2nd gen Tacoma
  67. 22re into a Chevy Luv
  68. finding a good engine..need help
  69. Difficulty?? Swap 1993 Tacoma 3.0 into 1998 4Runner (3.4)
  70. 85 22R into 83 pickup (2wd)
  71. 3.0 to 22RE
  72. Help me pick a motor for swap in my 82
  73. 6 cylinder engine swap
  74. Engine swap ideas/suggestions
  75. 3VZ-E to 3-VZE: Worth It?
  76. 1979 pickup
  77. Fuel problems
  78. engine swap cummins 4bt suppliers?
  79. tmgte into 1984 4x fixing someone elses mess.
  80. 22re swap nissian 200sx
  81. 22re swap nissian 200sx
  82. Want to swap out my 1zz-fe
  83. Rebuild advise on 3VZ-E
  84. 3vze Engine Swap Won't Run
  85. 83 pickup 22r to 87 4runner 22re
  86. Something a little different- Volvo
  87. A340e swap to R150f
  88. Engine Swap
  89. '89 Toyota 3.0 to 3.4L 5vzfe
  90. 1JZ supra engine in 1991 Toyota 4runner
  91. Which way to go from here
  92. 22ret to 22re swap help!!
  93. Engine swamo from 01 1.8L to 051.8L/Knock sensor
  94. 3vze auto to manual swap
  95. Building Truck, 2UZ or 1UZ?
  96. 2uz-fe with 4x4 trans to 2uz-fe with 2wd
  97. injector issues
  98. 2jzgte vvti 4runner 4x4
  99. Swap a 22RE manual into a 22re auto pickup
  100. 22r to 22re turbo
  101. Chevy 350 swap help
  102. 86 Toyota 4x4 engine swap Chev 350 and 4L60 front drive line trans pan no clearance
  103. 1999 Camry engine swap to v-6
  104. 1999 Camry engine swap to v-6
  105. T-case strength behind v8
  106. 3rd gen swapped into 4th gen
  107. will this head work?
  108. 1983 sr5 pickup 2jz twin turbo swap
  109. 1FZ in an '83 pickup
  110. Engine swap
  111. 4.3 vortec in 83 Hilux
  112. 2JZ Swap Questions
  113. One off swap
  114. 302 swap into a 1980 pick up...question
  115. 3vz-e to 22r trans
  116. Should I rebuild my engine in my 93 toyota pickup DLX or put a 350 or something else
  117. 92 pickup 3VZE into 95 SR5 4runner
  118. Parts swapping from different years
  119. Time to swap engines. Opinions wanted!!
  120. 91 toyota pickup 22re -> ?
  121. 1jz or domestic vortec 4.3, 4.8, 5.3?
  122. 3.4 swap into 1995 4runner
  123. 3.0 to 3.4 wiring HELP
  124. 4runner 3gen 4.0 v-8 swap
  125. 87pickup22r to 884runner3.0
  126. Throw me some ideas
  127. carbureted 4.3 swap fuel pump problem
  128. ls swap questions/post your pics
  129. 2jz
  130. Toy Swap stumped with Passlock problems.
  131. Mechanical 3RZ
  132. Engine Swap Problem
  133. Suggestions wanted. 1978 Chinook
  134. 2L or 2LT, orr?..
  135. Knock sensor code 52
  136. Performance 3vz build
  137. 3.4 swap CA ref - 3 linked front end
  138. 89 yota 4wd
  139. Run engine without transmission?
  140. Gasket or FIPG or both?
  141. Corrosion on camshaft lobes advice
  142. LJ72 Engine Swap help
  143. rebuilt 3VZ valve adjustment
  144. 350 3rd gen hilux swap- Trans questions
  145. Replace engine mounts?
  146. 350 swap 81 Hilux
  147. 96 Tacoma engine into 95 pickup ?
  148. Possibility of doing a 2004 4.8L Vortec Swap, Need some help plz.
  149. swapping my 83 to a vortec HELP!!!
  150. LS Swap Baja Runner Help!!! :help:
  151. 22r to 22re
  152. 3.0 V6 3VZE Dimension Questions
  153. ALH to '95 4Runner
  154. 4.3 toyota
  155. Need Consult on possible 1KZ TE to 95 4Runner Conversion
  156. rebuilt engine won't start with Weber carb
  157. 3.slow troubles
  158. 22R, pulleys dont line up with Harmonic Balancer
  159. 86 22re 5 SPD 4x4 to a 89 22 r 4 speed 2 WD just wanna swap motor will it work
  160. Ecotec swap
  161. I need engine swap w/ current tranny advise?
  162. 3.4 Swap into 92 Pickup: Verification
  163. small 350 idle problem
  164. 3VZ-E swap. Radiator Advice
  165. Anyone in LA?
  166. 1980 Toyota pickup engine swap ideas
  167. 3RZ Needs Custom Oil Pan for IFS
  168. 1986 to sbc 5.0 wiring help.
  169. Help on 82 22r engine swap
  170. 1986 Pickup V8
  171. advice on $1900 rebuilt 89 22re
  172. Most powerful engine in an 89 pickup
  173. 20R Break in- Really High Oil Pressure
  174. 1uzfe swap NEED HELP!!!!
  175. 1984 Toyota 2.4l diesel
  176. 2jz transmission options?
  177. What bell housing is this???
  178. Pick up vacuum 2.4l diesel
  179. electrical question for ppl REALLY sharp
  180. Want more power
  181. 4.3 location?
  182. 2tr into 95 pickup
  183. 1993 pickup 22rte
  184. Swapping 3.0's from auto to manual tranny...
  185. 500+ hp pickup?
  186. wiring harness from a 91 Toyota Pickup manual to a 3.4 engine
  187. fuel injection to carburetor
  188. 1996. 4 runner
  189. New 22re engine?
  190. 95 3.0v6 to 91 3.0v6
  191. Can't decide which Toyota engine to swap in
  192. Need help!
  193. LS Engine swap
  194. 87 xtracab 3.4 swap
  195. 22re to 22re engine swap...
  196. old 3.0 swap to rebuilt 3.0
  197. need to upgrade from a 3.0....
  198. 89 to 88 22re swap
  199. 95 Pickup Ext Cab 1uz swap
  200. 1984 block with 1985+ head?
  201. 88 3.0 to 92 22re any advice?
  202. 88 3.0 to fuel injected 4.3 (need pointers)
  203. Free 350+Trans
  204. 1994 3.0L into 1988 3.0L Truck
  205. 22r to 22re swap
  206. 1992 3.0 v6 to a 3.4 from a 1998
  207. Best Engine for Diesel swap
  208. 1980 pickup
  209. 96 T100 4x4 5spd SWAP HELP
  210. 1988 4 runner connector identification
  211. 1988 engine to body harness connector identification
  212. 1988 3.0 auto to 1999 3.4 auto swap wiriing questions.
  213. 4.3l swap what else do I need????
  214. 94 22re wiring question?
  215. 98-00 1UZ-FE in 95 4Runner swap?
  216. 5.9l swap???
  217. 3rz rough idle on hot starts.
  218. Engine swap
  219. Surefire? Powertorque? Long block
  220. 350 engine swap in 85 4runner
  221. 22r-ec to 22r
  222. Swapping 2F to 1JZ-GE
  223. VW swaps
  224. 94 exhaust O2 location for 97 3.4 swap
  225. 4.3 vortec swap? help!
  226. Swap in Progress 1994 4wd/AT 3.0~3/4
  227. Engine swap. NEED HELP
  228. 89 4runner engine swap...BEST CHOICE!?!?
  229. 22r to a 2rz from a 00' tacoma
  230. TIS subscription
  231. 88 yota v8 swap
  232. NW team yota engine swap
  233. 3rz engine search for my swap.....
  234. 1uzfe questions, sump choice and where to buy.
  235. 2.7 swap
  236. 85 with an 86 22r
  237. Evap hose not hooked up. Can't find where it goes.
  238. 1uz in a 92 2wheel drive Toyota ?
  239. 3RZ swap oil pressure question
  240. 3rz Swap Oil
  241. 3rz VIN found on block?
  242. What year shortblocks fit an 87?
  243. 3.4 swap need help
  244. 88 22r into 82 22r
  245. 2.8 i6 to 86 hilux?
  246. Are you happy with your swap?
  247. Help, Oxygen sensor question in 22re engine swap!
  248. 86 22re 2.4 manual in a 89 22re 2.4 body
  249. 89 Runner 3RZ Swap Thread
  250. 4bt? anyone
