Engine Swaps Swapping an engine in your Toy, here is where to learn how
3.0 to 22RE
Old Nov 14, 2018 | 07:30 PM
Greg Zelner's Avatar
3.0 to 22RE
I work on outboard motors not cars so this is a new project for me. I see people going bigger but not smaller. Have a 91 toyota pickup rv with a 3L v6 with low compression. Found a 22RE 4 cylinder motor only for dirt cheap. What frame modifications or parts would i need that arent going to be directly swappable? Mine is also an auto transmission, im not sire what the 22re is yet.
Old Nov 15, 2018 | 07:32 AM
gsp4life's Avatar
A long block 22re is the same for manual or automatic transmission. I don't know much about the 3vze but I know you'll definitely need a wiring harness and ecu. The entire intake and exhaust (at least up to the cat) would be different as well. Do you know if the engines share a flex plate and torque converter? You'll likely need a bunch of brackets and other parts to fit the 22re and have it work right so I hope you have an auto tranny 22re donor vehicle to work with.
Old Nov 15, 2018 | 07:34 AM
Co_94_PU's Avatar
Just about everything from the axle forward gets changed or modified.
A dirt cheep motor you say? If you can not see it run and drive it it might not be worth the asking price unless they really want to swap for dirt. Does it include the vehicle?
Old Dec 26, 2018 | 05:22 PM
Smaay's Avatar
please do NOT put a 22R in you vehicle. either get another 3.0 or upgrade to a 3.4
4banginRunner
All Other Toyota Swaps
21
Jul 11, 2011 03:50 AM
yotaboy66
Dec 14, 2006 04:05 PM
tlake
Oct 24, 2006 06:49 PM
surtur
Dec 11, 2005 06:41 AM
wifesaysimadumbass
Mar 27, 2004 03:30 PM
